Glop toner help
Glop toner help
2014-05-30 by benedictchen22@...
Hello
I have a PK+ LK + LLK profile linearized
I like to add a reverse curve to apply Glop.
I not sure how to create the ACV curve.
could some one advise please! or point me the right readings to do could not find it in the help or guide =(
Re: [Digital BW] Glop toner help
2014-05-30 by Paul Roark
UT14 had glop in the Y position. The curves I made for that inkset will show you some examples. The URL to the Profiles Zip file is on page 2 of http://www.paulroark.com/BW-Info/UT14.pdf .
I found the glop curve was somewhat trial and error. Print a 21-step and see where more (or less) is needed.
Keep an eye on pizza wheel marks. That is one of the potentially negative side effects of too much glop.
Good luck.
On Fri, May 30, 2014 at 5:20 AM, benedictchen22@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
Hello
