Fade testing data for MIS UT-14 inks?
2014-06-27 by mccarvill@...
Can anyone point me to any current, third-party fade test results for MIS UT-14 inks (or equivalent)?
I found nothing on the Wilhelm Imaging site, but then again I find that site challenging to use. On Aardenburg, I found some old results for MIS, but nothing on UT-14.
On the MIS Web site, they’ve posted 2003 results from their own testing of Ultra-Tone inks, which is somewhat helpful, but these results are 11 years old, aren't independent, and may not reflect the current UT-14 formula. Elsewhere, they say “The Ultratone inks are all extremely archival. Our tests indicate that they will far exceed 100 Wilhelm equivalent years.” But when I asked MIS for a link to the data that backs this up, I got nothing. When I asked MIS about UT-14 specifically, they said “We've never done archival tests on the UT14 inks but the pigments are rated over 100 years.”
I'd submit my own test patches to Aardenburg, but they’ve stopped accepting submissions.
Mark
Re: [Digital BW] Fade testing data for MIS UT-14 inks?
2014-06-28 by Paul Roark
The carbon (warm)channel is extremely light fast. The cool channel has color pigments in it, as well as carbon. The color pigs are not as solid as Epson or HP pigs. As such, while the lab l performance was very good, there will be some color shift. In my comparative testing the MIS inks performed much like Jon Cone's. Jon's inks are tested on AI&A.
On Jun 27, 2014 6:25 PM, "mccarvill@... [DigitalBlackandWhiteThePrint]" <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
On the MIS Web site, they’ve posted 2003 results from their own testing of Ultra-Tone inks, which is somewhat helpful, but these results are 11 years old, aren't independent, and may not reflect the current UT-14 formula. Elsewhere, they say “The Ultratone inks are all extremely archival. Our tests indicate that they will far exceed 100 Wilhelm equivalent years.” But when I asked MIS for a link to the data that backs this up, I got nothing. When I asked MIS about UT-14 specifically, they said “We9;ve never done archival tests on the UT14 inks but the pigments are rated over 100 years.”
Mark
Re: Fade testing data for MIS UT-14 inks?
2014-06-28 by homershannon@...
I've been using the UT-14 ink set for several years. I have no scientific data on how it fades, but I have prints that have hung for at least three years and I cannot see any evidence of fading. From what I can tell, unlike color dye inks, you really don't have to worry about fade with this ink - or for that matter any of the carbon-based inks.
2014-06-29 by mccarvill@...
Thanks for the replies, folks.
@ Paul: I count only 7 / 23 Aardenburg test results for Cone that show a PASS, so I'm not sure what to make of this as a comparison with UT-14.
@ remononaz1: Would you say your prints are warm, neutral, or cool? The warm prints (with the least cool toner) seem to fade the least.
Mark
2014-06-30 by homershannon@...
Mark:
I would say that UT-14 prints a neutral tone. I have experimented with changing the tone using curves and created neutral and warm tone curves for printing on glossy paper. The curves limit the amount of ebony in so that there are no problems with smearing on glossy paper. I don't normally use these on matte papers as matte papers have no problems with the ebony ink, but I don't see any reason they would not work if you wanted a warmer tone.
I posted a set of instructions for using these at http://1drv.ms/1qJPklL and the article has links to the actual .acv files that you will need to download and put into your Photoshop director.
Homer Shannon
