I started with the first Genuine Fractals and have used every
permutation since \u2014 up to and including the latest "Perfect Resize." I
have always had satisfactory results. The latest versions give you some
options that are best done in Photoshop (IMHO), sharpening being one of
those.
Joe
On 10/22/2014 21:36, Paul Roark roark.paul@...
[DigitalBlackandWhiteThePrint] wrote:
> The only testing I've done on up-sizing relates to minimizing the
> losses where there are geometric alterations in the file, like in
> stitching. In those cases a "smart" up-res (old Genuine
> Fractals/Perfect Resize or -- better -- PS CC in auto mode) of 200%
> does seem to preserve details. See
> http://www.paulroark.com/BW-Info/Perfect-Resize-comparison.jpg
> Paul
> www.PaulRoark.com <http://www.PaulRoark.com>
> On Wed, Oct 22, 2014 at 3:40 PM, Myron Gochnauer goch@...
> <mailto:goch@...> [DigitalBlackandWhiteThePrint]
> <DigitalBlackandWhiteThePrint@yahoogroups.com
> <mailto:DigitalBlackandWhiteThePrint@yahoogroups.com>> wrote:
> Is there any received wisdom on when resizing of an image should
> be done during processing?
> >From experience, but not careful testing, I do any upsizing in
> Photoshop as early as possible in my processing, but after I have
> performed any necessary noise reduction.
> My untested thinking is that upsizing before noise reduction might
> make noise reduction less reliable, since upsizing always involves
> *some* degree of guessing and so has some reasonable likelihood of
> producing random noise artifacts. (I use noise reduction plugins
> that rely on analyzing the image, or a representatively similar
> image. The more uniform and predictable the noise is, the better
> they seem to work.)
> Have any of you done careful tests to solve this problem? If not,
> does my approach seem sensible?
> Every time I decide I should test this, I run into complications
> in the nature of \u201cwell, it depends. . .\u201d. And, of course, it
> usually doesn\u2019t make any visible difference at all when I finally
> just get it up on the wall. :-)
> Myron
Joe Dempsey
870.550.0191
http://www.joedempseyphoto.com/
http://www.corndancer.com/joephoto/photohome.html
http://weeklygrist.wordpress.com/
