2014-11-28 by richard@...
No, that is not correct—at least not how I have ever used QTR or my understanding of how ICC profiles work, with QTR or normal OEM printing. There is no way the Epson driver will define how much of each of the different dilutions to lay down when using a 6 gray ink inkset no matter what ICC profile you use. Especially if the ICC profile created was made using QTR.
When you define the "paper" you want to print on using QTR, you are defining qtr profile (the set of overlapping ink curves) that has already had the ink limits, overlaps, gray curve, toning inks, and final linearization already set.
When you drop the measurement data file from the 21-step file onto the linearize data script all you are doing is stripping all the XYZ and header information out of the measurement data and getting you a string of L*ab values (as measured—not corrected for linearity) and a graph. If you are creating a profile from scratch you can then take that LINEARIZE="..." string and paste it at the end of the .qdif/.txt file, then resave and re-run the install script (on a mac). There is a behind the scenes function that takes the measument data and creates a new .quad file that is adjusted for linearity.
You then reprint a 51-step target with the new profile to confirm the linearization was succesful and to create the ICC profile for that paper and QTR profile so it makes corrections for what is printed and what is defined in the file. You don't actually need to run the linearized measurement data file through the linearize data script again. You just need to run the create icc, (which gives you the same graph as the linearize data script) and icc profile (as long as the lab values are constantly increasing).
If you print with the ICC profile you just created you still need to define the QTR Profile for that paper and printer, in addition to the ICC profile that you created for that paper and printer. It is like using the same media settings used to create an RGB ICC profile with a normal color managed workflow using the OEM driver or higher end RIP. If the printing parameters are different than what was used to create the profile then the correction will be off.
If you print through photoshop with "photoshop defines colors" using the correct ICC Profile you still need to set the associated QTR profile in the "print settings" window.
I have never worked that way. For the majority of my work, I always preferred the linear "curve" and more open shadows that the no color management settings give and never bothered to use the QTR icc profiles, except to occasionally soft proof. That being said, my own workflow is based on years of doing it the same way and being able to predict the results of the prints based on the profiles I make, and not using an ICC profile or other default correction curves/transfer functions for different papers.
Hope this clears some of this up and doesn't stir up the much too much.
Richard Boutwell
