Mobile friendly websites
2015-04-18 by roark.paul@...
In today's world, having our web pages be mobile friendly is worth a little effort. Apparently Google is going to be using this as one criteria in ranking search results.
Many of our pages are not mobile friendly. You can test your URL at this Google website:
https://www.google.com/webmasters/tools/mobile-friendly/
Typical of the problems you might see is that your text is too small to read, the links are too close to easily touch with a finger without getting the wrong link, and your images are too wide.
I am not a coder, but I do hand code my web pages. So, I had to find some very simple solutions. Here is what worked for me to fix the above problems.
First, insert this text in the header:
<meta name="viewport" content="width=device-width, initial-scale=1.0">
This meta viewport tag gives the browser instructions on how to adjust the dimensions and scaling of the page to the width of the device.
Second, I just added breaks between links that were too close.
Third, this CSS code in the HTML header takes care of the image scaling:
<style>
img {max-width: 100%}
</style>
I don't use separate style sheets, so just inserting this in the HTML page header was a simple solution.
Again, I'm not a coder, and I'm sure many on this forum are much more sophisticated about this. But, these modifications to the webpages I write have, so far, allowed them to pass the Google "mobile friendly" test, which could be increasingly important to be found on searches.
PaulRoark.com -- Paul Roark's Photographic Home
