Re: from a 7800 to 3880?
2015-07-08 by arlenelove3@...
The reason I am abandoning my 7800 is because Epson makes it impossible to
repair old printers.  Parts are not available. The certified  person  who
used to come to my studio no longer makes "house calls" because he can't get
parts. Epson will send a person for a charge of $100 transportation plus
$175 an hour, and a possible cost of $400 for a part. - if it's available.
The nearest certified repair place ( 60 miles away) is not eager for  me to
shlep the printer to them.
 If Paul Roark OK's the 3880 as good for B&W matte prints., I  believe it!
However, it seems that 3880 has been discontinued for the  new P800, and I
wonder if I will have the same problem getting parts that I have  with the
7800.
If anyone can use my 7800  for parts, come and get it. I also have  some K3
220 ml carts and HPR and EEM roll paper.
                                          Arlene
ARLENE LOVE
arlenelove3@...
Philadelphia, PA 19130
215 923  2363
Re: [Digital BW] Re: from a 7800 to 3880?
2015-07-08 by Dr. Elliot Puritz
Others will have more knowledge about printers than I have.  Certainly the 3880 is a great printer and likely has a few features that are missing from the 1430.
However, if one has any thoughts about using multiple monochrome ink sets and tones then surely the currently available and inexpensive1430 deserves your investigation.  Indeed, if you have the space, one can buy two ( or more )1430 printers for the same price as the discontinued 3880 and be assured of both parts and service.
Why worry about being able to repair a discontinued Epson printer?
It is increasingly obvious that Epson is hoping to "remove" the small( but growing ) segment of "independent" black and white digital ink jet printers who want to use inks from other manufacturers. In a short time such artists will find themselves having more and more trouble finding printers that will support their efforts...
One must hope that a way will be found to work around the physical AND software issues that are likely part of the new Epson printers.
> On Jul 8, 2015, at 9:16 AM, arlenelove3@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
> The reason I am abandoning my 7800 is because Epson makes it impossible to repair old printers.  Parts are not available. The certified  person who used to come to my studio no longer makes "house calls" because he can't get parts. Epson will send a person for a charge of $100 transportation plus  $175 an hour, and a possible cost of $400 for a part. - if it's available.
> The nearest certified repair place ( 60 miles away) is not eager for me to shlep the printer to them.
>  If Paul Roark OK's the 3880 as good for B&W matte prints., I believe it!  However, it seems that 3880 has been discontinued for the new P800, and I wonder if I will have the same problem getting parts that I have with the 7800.
> If anyone can use my 7800  for parts, come and get it. I also have some K3 220 ml carts and HPR and EEM roll paper.
>                                          Arlene
> ARLENE LOVE
> arlenelove3@...
> 215 923 2363
2015-07-08 by hrblaine@...
Didn't I read that the 800 has a very high D Max?
In a message dated 7/8/2015 12:16:59 P.M. Eastern Daylight Time,
DigitalBlackandWhiteThePrint@yahoogroups.com writes:
2015-07-08 by Paul Roark
Where you live and whether you can transport your printer to a good repair shop are obviously important variables when it comes to large printer repairs. I have a van and easily transported my 7800 to the Los Angeles area for repair. It worked out very well. I highly recommend "Printer Repair Pros" in Chatsworth, CA -- http://printerrepairchatsworthca.com/ .
I just talked to the proprietor and asked how long the 7800 and 3880 printers will likely be supported by Epson. His response was that for the pro line (which these printers are a part of), Epson usually has parts available for 10 years. The 7800 parts are still "pretty much" available, and the 3880 is in very good shape.
As to the 3880, the only weak point from a repair person's perspective appears to be the mechanism that switches between matte and photo black inks. I might add that on the 3880 I'm using the PK is non-functional. I don't know if it's that valve or other cause, but since I just leave it on MK with the Eboni-6 inks, I have not found any problem with the situation. (I have the generic clear base in the PK cart, and if it is the valve, it worked fine in the power cleanings used to clear the old color inks out of the lines.)
Bottom line, I continue to believe that the 3880 is going to be an excellent platform for a large segment of avid B&W photographers, including those who like the quality and cost savings of dedicated B&W inksets. Most people will be able to transport the 3880 about as easily as a 13" paper printer, and it is likely to have parts available for a long time.
On Wed, Jul 8, 2015 at 9:16 AM, arlenelove3@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
Arlene
ARLENE LOVE
arlenelove3@...
215 923 2363
Thanks Paul.
From a practical viewpoint for small volume printing what are the advantages of the 3880 vs. the 2880 and the current 1430? Certainly not the ease of switching carts.  I know that there is the perceived advantage of using rolls and therefore printing to a larger size.  The paper feed on the 3880 is certainly better than the 1430.However many here will likely have little reason to print supersize-even if our digital files supported such printing.
I simply wonder what one gets for the additional money.  I assume of course that one can buy either a new or refurbished 3880 guaranteed from Epson.
Note again "small volume printing"
Do you really trust Epson to maintain TEN YEARS of parts??
> On Jul 8, 2015, at 11:48 AM, Paul Roark roark.paul@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
> Paul
> www.PaulRoark.com
>> Â
>> Â
>> The nearest certified repair place ( 60 miles away)Â is not eager for me to shlep the printer to them.
>> Â
>> Â
>> If anyone can use my 7800Â  for parts, come and get it. I also have some K3 220 ml carts and HPR and EEMÂ roll paper.
>> Â
>> Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â  Arlene
>> ARLENE LOVE
>> arlenelove3@...
>> 215 923 2363
Enough to really matter?  I wonder.
> On Jul 8, 2015, at 10:29 AM, hrblaine@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
> In a message dated 7/8/2015 12:16:59 P.M. Eastern Daylight Time, DigitalBlackandWhiteThePrint@yahoogroups.com writes:
2015-07-08 by Matt Haber
Does the 3880 have a vacuum feed?
2015-07-08 by David Whistance
No it doesn’t have vacuum feed. I’ve always thought of the 3800/3880 as essentially a larger desktop printer as opposed to the professional models which start properly with the 4xxx series. As a result I’ve always found the paper feed on my two 3800’s very fussy compared with the 9800’s, 7880’s or 4800’s I also have. Still produces nice prints though, just very frustrating at times when the larger models aren’t.
I see the benefit of the 38xx series as being the bigger cartridges compared with the other desktop machines although if you are refilling with B&W inks that isn’t really worthwhile. They also give you a larger print size in a smaller unit - the 4xxx series are really much bigger.
David Whistance
On 8 Jul 2015, at 23:47, Matt Haber matt@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
2015-07-08 by Cdtobie
I've been dealing with the 3880 vs P800 issue directly with Epson. They are adamant that the D-max improvement is significant. Since they were not adamant enough to send me a prerelease P800 for testing, I can't yet confirm that, but I believe them that it is not just measurable, but visible. Time will tell.
C. David Tobie
Blog: cdtobie.wordpress.com
Site: cdtobie.com
> On Jul 8, 2015, at 6:37 PM, 'Dr. Elliot Puritz' drpuritz@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
> Sent from my iPhone
Yes, really big desktop printer, with tolerable cart sizes. You don't want anything less, but you may want something more.
C. David Tobie
Site: cdtobie.com
> On Jul 8, 2015, at 6:56 PM, David Whistance david.whistance@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
> David Whistance
2015-07-09 by Paul Roark
The reason to get a 3880 is to be able to print on 17" wide paper as opposed to 13" paper. In my view the 16x20 inch print was the standard for wall display for B&W for years. A 3880 can do that, the 13" models look a bit small on the wall.
So, if you meant by "small volume" small size, then there is no advantage to the 3880. If 13" paper is enough, I'd go for the 1430. Having small carts on the moving carriage agitates the inks automatically. With the 3880, you'll have to agitate the carts every couple of weeks for good consistency.
I do "trust" Epson to have parts available for a reasonable time. It's not an egalitarian move by them. People would be reluctant to buy their products if Epson got a reputation for cutting off parts supplies too soon. This particularly applies to expensive pro models.
On Wed, Jul 8, 2015 at 3:36 PM, 'Dr. Elliot Puritz' drpuritz@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
Thanks Paul.
As to the 3880, the only weak point from a repair person's perspective appears to be the mechanism that switches between matte and photo black inks. I might add that on the 3880 I'm using the PK is non-functional. I don';t know if it's that valve or other cause, but since I just leave it on MK with the Eboni-6 inks, I have not found any problem with the situation.  (I have the generic clear base in the PK cart, and if it is the valve, it worked fine in the power cleanings used to clear the old color inks out of the lines.) Â
Â
Â
Â
Â
Â
                                        Arlene
ARLENE LOVE
arlenelove3@...
215 923 2363
2015-07-09 by Dr. Elliot Puritz
Good points David.
Let me present an alternate scenario for some who desire to make the best digital fine art print possible. In the occasional instance when one wants to print to a larger size it might make more sense to engage the services of a professional printer. One can develop an excellent relationship with a person who makes his/her livelihood printing editions for digital photographers. In the development of a professional relationship the expert printer will often be aware of the vision that each client has, and will match the paper and inks to the print desired.
There are many well thought of digital photographers who are no longer printing their own work.  That is not to say that they relinquish control of their own work; they simply work with a printer so as to achieve the best results.
Certainly I'm aware that price considerations will often drive printing decisions.
Needless to say the same approach regarding the use of expert printers has been used by analog photographers for many years.
There will likely be no appreciable difference in the appearance of an 11x14 black-and-white digital print made on the same paper using the 3880, 3000, 2880, or 1430. Indeed one wonders if there will be any appreciable difference up to a print of 13 x 19 or even slightly larger.
Note of course I am alluding to prints made from the same black and white ink sets, i.e., the same number of carts with the same shades of MIS or Cone inks.
The" pros" here may well need a professional model printer. It is likely that many of us do not.
> On Jul 8, 2015, at 3:56 PM, David Whistance david.whistance@btopenworld.com [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
> David Whistance
I guess I am just a bit more of a skeptic Paul.  Parts will be available for the older printers but I doubt there will be new parts for 10 years. Epson will need to scavenge parts from older printers– just like auto junk shops.
Incidentally we are all assuming that there won't be some amazing breakthroughs in the digital printing process that will make all current printers completely obsolete. In such case our interesting discussion will moot....
> On Jul 8, 2015, at 5:02 PM, Paul Roark roark.paul@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
> Paul
> www.PaulRoark.com
>> Â
>> Thanks Paul.
>> Do you really trust Epson to maintain TEN YEARS of parts?? Â
>> Sent from my iPhone
>>> Â
>>> Paul
>>> www.PaulRoark.com
>>>>                                          Arlene
>>>> ARLENE LOVE
>>>> arlenelove3@...
>>>> 215 923 2363
Small volume suggests one that is not making too many prints Paul.
I'm glad we agree that small print sizes would not require any model other than the Epson 1430.
 Although it's not terribly important I suggest we might have a small disagreement about normal print sizes. For a considerable period of time contact prints from 8 x 10 negatives were standard.
> Paul
> www.PaulRoark.com
>> Â
>> Thanks Paul.
>> Sent from my iPhone
>>> Â
>>> Paul
>>> www.PaulRoark.com
>>>>                                          Arlene
>>>> ARLENE LOVE
>>>> arlenelove3@...
>>>> 215 923 2363
2015-07-09 by Mark Haffey
There is a pretty thorough review of the P800 by Mark Segal on the
Luminous Landscape.  I don't know if you would trust his info but it
could be helpful in making your printer decision.
Mark Haffey
On 7/8/2015 7:03 PM, Cdtobie CDTobie@...
> C. David Tobie
> Blog: cdtobie.wordpress.com <http://cdtobie.wordpress.com>
> Site: cdtobie.com <http://cdtobie.com>
> <mailto:drpuritz@...> [DigitalBlackandWhiteThePrint]
>> Sent from my iPhone
>> <mailto:hrblaine@...> [DigitalBlackandWhiteThePrint]
>>> <mailto:DigitalBlackandWhiteThePrint@yahoogroups.com> writes:
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
2015-07-09 by hrblaine@...
Not speaking for Paul but as an interested 3rd party who owned both a 1400
and a 3800, I will say that you are talking about two different  things.
And yes, back in the day when I was shooting a 35mm Nikon, my  developer
always gave me an 8 x 10 contact print of all the negatives.  But  I never
displayed them on a wall, did you?  Harry
In a message dated 7/9/2015 12:42:49 A.M. Eastern Daylight Time, AL  writes:
2015-07-09 by David Whistance
I suspect Dr Purlitz was actually referring to the days of Steiglitz, Weston, etc when larger size film was the norm and the only prints were contact prints, ie the same size as the film and made by putting the film and paper in contact together under a light source. At that time 10"x8" prints were regularly displayed on the wall as indeed they still are. The contact prints you are talking about are a rather different animal, albeit made in the same way. For my own work I really like 10"x12" prints even though I can print much larger.
David Whistance
> On 9 Jul 2015, at 12:29, hrblaine@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
> Not speaking for Paul but as an interested 3rd party who owned both a 1400 and a 3800, I will say that you are talking about two different things.  And yes, back in the day when I was shooting a 35mm Nikon, my developer always gave me an 8 x 10 contact print of all the negatives.  But I never displayed them on a wall, did you?  Harry
I regularly matted and framed my contact prints on Azo.  Many still hang on my walls...😀
> On Jul 9, 2015, at 04:29, hrblaine@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
David has an interesting point:  Although one can make larger prints smaller prints have an intimacy that often complements a particular image .  It's great to have options that include size, ink tones, mats, etc.
> On Jul 9, 2015, at 05:07, David Whistance david.whistance@btopenworld.com [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
> David Whistance
> Sent from my iPad
Well good for you but I was talking about proof sheets.
In a message dated 7/9/2015 10:49:12 A.M. Eastern Daylight Time,
on  my walls
Back in the day when I was shooting 35 mm, probably 95%+ of my prints were
8 x 10.  Now that I'm printing my own stuff, it's still lots of 8 x  10
but more large prints, color ones especially.  BW prints  arre still pretty
much 8 x 10.
In a message dated 7/9/2015 11:07:27 A.M. Eastern Daylight Time,
Sorry....😉
> On Jul 9, 2015, at 10:57, hrblaine@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
> In a message dated 7/9/2015 10:49:12 A.M. Eastern Daylight Time, DigitalBlackandWhiteThePrint@yahoogroups.com writes:
