New QuadToneRIP version 2.7.6 for Mac and PC
2015-09-04 by roy@...
QuadToneRIP version 2.7.6 Release Notes
This is both a Mac OSX release and a Windows release.
The primary additions are for two new Epson printers: P600 and P800
These printers have a new ink set from Epson called UltraChrome HD.
They are very similar to previous set but blacks are a bit darker
and a bit more neutral by themselves. This means there are new profiles.
The profiles were made and linearized with the P600. They should work
well with P800 but if you have re-linearization capability it may be worth it.
There is a new droplet QTR-Linearize-Quad which allows re-linearize a .quad
file directly. Simply drop a .quad file and a measured-patches-data file (.txt)
onto the droplet together. A new .quad file will be created.
Roll Feed has been enhanced for the Save Roll Paper option on all
the Pro printers supporting rolls plus the R3000, R2880, and R2400 printers.
With this option you can have a long roll paper size and if you only have
images on the leading part all the blank white is chopped off
minimumizing wasted paper. This is the same as Epson driver Save Roll Paper.
The Mac release supports Mac OS X 10.6 Snow Leopard through 10.10 Yosemite.
Windows release supports Windows XP through Windows 8.
Note that the version number in QTRgui reads 2.7.0 but you can see
the 2.7.6 version number for QuadToPrinter in the Help>About command.
Simply install this new version over existing versions.
