[Digital BW] Re: Abort print..
2002-03-31 by wilfred71118
--- In DigitalBlackandWhiteThePrint@y..., Alan Zinn <AZinn@n...> wrote: > At 07:06 PM 3/31/2002 -0000, you wrote: > >If it's still being "sent to printer" you can cancel it by hitting > >the escape key. I don't think that works once printing has begun... > >at that point, I think hitting the paper feed button or turning off > >the printer is your only choice... when you turn off the printer, you > >probably need to disconnect it from the pc so it doesn't start up > >again when you turn it on...then reconnect to pc. > > > >Tom O'Connell > > > > > > On a PC with the 6.x version of piezo ESCAPE works if the printing has started. > > AZ > Maker of Lookaround panoramic camera. > > http://lookaroundcam.com/ > or > keyword.com lookaround >Thanks, I just tried it out. I hit the escape key. It did abort the print job, but photoshop locked up also. Well at least I had the image saved.
