Print mounting.
Print mounting.
2002-04-14 by wilfred71118
I am about fed up with the warping that happens when dry mounting on
mount board. I was wondering if any one has been using a product
called Ultra Mount. I have seen a sample of this stuff. It looks like
it would be the answer to no warping using mount board and no dents
with foam core. It is tough and light. I am now searching for the
least expensive outlet for it. Anyone with any ideas?
RE: [Digital BW] Print mounting.
2002-04-14 by Austin Franklin
> mount board.
I use a product from Bainbridge, called "Foamboard".  I get no warpage at
all (below my perception level at least ;-)...
Austin
Re: [Digital BW] Print mounting.
2002-04-14 by Jerry Olson
You probably shouldn't be mounting prints using dry mount. Use the
archival tape hinge method. Much safer, many less problems. And the
prints do lay flat, when matted. And no part of the print is attached
directly to the mount/backing board.
Jerry
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and other resources as they are often being updated. The page is at:
> - Good manners are required at all time. No personal attacks or "flames."
> - Before posting a question, search the message archives and the various resources on the homepage.
2002-04-14 by David Dyer-Bennet
Jerry Olson <jerryolson@...> writes:
Conservators certainly prefer prints not to be dry mounted or in any
other way permanently bonded to anything.
However, I've never gotten a print to lie satisfactorily flat using
archival tape hinges, and the over-mat doesn't help any that I can
see.
Currently I'm just living with it.  If I had room and money I'd
probably buy a press and go back to dry mounting, because the results
look so much better.  And dry mount is known to be reasonably
well-behaved over time, too.
David Dyer-Bennet, dd-b@...  /  Ghugle: the Fannish Ghod of Queries
 John Dyer-Bennet 1915-2002 Memorial Site http://john.dyer-bennet.net
        Book log: http://www.dd-b.net/dd-b/Ouroboros/booknotes/
                 Photos: http://dd-b.lighthunters.net/
2002-04-14 by Alan Zinn
You shouldn't be getting warps. Put the board in the press to dry it out
before you mount on it.  Lay the dry mounted print under a 18 x 24 or larger
piece of plate glass immediately after it comes out of the press. Check your
temp - it shouldn't be above 180-190 degrees. The self-adhesive stuff will
cost more and may be a nuisance to position the print on it. I don't know if
it is re-positionable.
AZ
AZ
Maker of Lookaround panoramic camera.
http://www.geocities.com/SoHo/Gallery/8874/
         or
keyword.com lookaround
2002-04-15 by Jerry Olson
David, possibly you are using too thin a paper and laying down the ink
too heavily. I have no problems at all with the prints not lying flat.
Jerry
> see.
