Re: [Digital BW] Re: Loading Roark Curves for MIS Inks
2002-04-22 by Brian Ellis
Thanks very much, I actually finally figured that out yesterday. I didn't realize that "extract" in the PKZIP program means decompress. Once I ran the extraction part of the program the curves downloaded fine. Of course the prints look terrible but I've posted another message about that problem. Brian ----- Original Message ----- From: "charles_bandes" <byronbulb@...> To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Monday, April 22, 2002 8:57 AM Subject: [Digital BW] Re: Loading Roark Curves for MIS Inks > This is easy - > > .zip files are a compressed file format, they need to be uncompressed > before you can get at the goodies inside them. Run that file through a > decompression program like Stuffit Expander or Winzip, and then you > can access the .acv files stored inside it. > > Goof luck :) > > --- In DigitalBlackandWhiteThePrint@y..., "vinyo88" <orlandovl@h...> > wrote: > > --- > > I had the same problem when trying to install Pauls curves for the > > variable mix inks. After several conversations with Paul I tried > > downloading them with a different web browser and voila they worked > > fine. > > > > Vinny > > > > > > In DigitalBlackandWhiteThePrint@y..., "bellis33624" <bellis60@e...> > > wrote: > > > I've installed the MIS variable mix inks in my Epson 1160 printer. > > > I'm trying to load the Paul Roark curves for these inks. However, > > > when I open Photoshop, select curves, select "Load" and enter the > > > file name (1160pc.zip) I receive a message to the effect that this > > > file type cannot be used with this version of Photoshop (Photoshop > > > 6). I don't know whether this message means that zip files in > > general > > > can't be used or that this particular curve file can't be used. In > > > any event, if anyone has any suggestions as to how this curve can > > be > > > loaded with Photoshop 6 (or can confirm that it is simply not > > usable > > > with Photoshop 6 or can provide access to a different curve for the > > > variable mix inks) I'd appreciate hearing from you. > > > > Please visit the Group Homepage to check the Files, Bookmarks, Polls and other resources as they are often being updated. The page is at: > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > Please follow these basic guidelines: > - Include your full name with your message. > - Include the address of your website, if you have one. > - As threads develop, trim off excess portions of earlier messages to keep them short. > - As the topic of a thread changes remember to change the subject header. > - Good manners are required at all time. No personal attacks or "flames." > - Complete your Yahoo profile. > - Before posting a question, search the message archives and the various resources on the homepage.
> > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > >
