only half OT
only half OT
2002-04-25 by Julian Thomas
I'm trying to think of ways to output a series of montages which contain
both colour and BW images. is there an inkjet solution??
Julian
Julian Thomas
Bruc 168-6-1
08037 Barcelona
Website at www.foundobjectsgallery.com
current exhibition: www.thesight.com
Gallery at http://www.mwords.co.uk/galleryGuests.htm#
Streetphotography at
http://www.borderless-photos.de/jthomas/jthomas-01.html
tfno 679676321
Re: [Digital BW] only half OT
2002-04-25 by meander@mail.dk
> Julian
In the old days, about 3-4 years ago, People reported success with
double printing in creating paper negatives for contact printing. Two
negatives of the same image was made in PS,  one for high lights, one
for shadow or to control density in part of the print to suit the
contact printing process being used; and each negative was printed on
the same sheet of paper, passing the same sheet through the printer
twice. Success will depend on how good the paper feed/registration is on
the printer you are using. Probably worth a try.
If the final print is  slightly out of registration then maybe altering
the montage will hide or maybe even add to it .
Jerry.
Thanks Jerry, I'll run some tests.
Julian
Sent: Thursday, April 25, 2002 3:13 PM
Subject: Re: [Digital BW] only half OT
> > Julian
> Jerry.
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and
them short.
> - Good manners are required at all time. No personal attacks or "flames."
resources on the homepage.
2002-04-25 by dickbo
Sent: Thursday, April 25, 2002 2:13 PM
No, but there is a photoshop one.
I'm doing it in PS! But I need an output solution. And it needs to be
archival otherwise the new epson 7ink printer might do...
Julian
Sent: Thursday, April 25, 2002 5:05 PM
> From: <meander@...>
contain
them short.
RE: [Digital BW] only half OT
2002-04-25 by Nij
Hi Julian,
Didn't John Brownlow (or someone) do some test with repeated running through
a printer and find that alignment was excellent (on the second print) as
long as you marked your paper's edge on the printer? If that's the case...
it ought to be possible to do similar with two printers... but it would take
a bit more effort I'm sure.
Nij
> From: Julian Thomas [mailto:julianthomas@...]
> Sent: 25 April 2002 16:22
> Julian
Are you claiming it is possible to inch the paper in the feeder?
Sent: Thursday, April 25, 2002 5:36 PM
Subject: RE: [Digital BW] only half OT
> Hi Julian,
through
take
> Nij
> > Julian
them short.
2002-04-25 by Nij
In roll feed mode it is to some extent... but my recollection is that tests
by <someone> showed you could refeed sheets with remarkable 'vertical'
accuracy... and if you marked the exact edge you used with some tape or
whatever... then you should get some form of alignment.
Sorry, just regurgitating info second-hand.
Nij
> From: dickbo [mailto:Dickbo@...]
> Sent: 25 April 2002 23:22
> From: "Nij" <nigel@...>
> > Hi Julian,
> through
> the case...
> take
> > Nij
2002-04-26 by Tim Spragens
Julian,
I'd think your problem might be choice of paper. What are you
expecting to print on, even if you get decent alignment? Your layout
could be loose enough to accept some slop in printer loading.
Tim
> Julian
Tim Spragens
http://www.borderless-photos.com
