Re: [Digital BW] Trouble with Piezo and MIS
2002-05-11 by Jerry Olson
Try Paul Roark's curves. I get really good prints with the MIS VM inkset.
Jerry
sdsmith9999 wrote:
> Hello group:
> I've switched from Cone inks to MIS FS.  Too much clogging in my 1140
> with Cone inks.
> Using MIS, I get nice tonal range with the Woolf curve but the dots
> are too visible.
> Images that printed wonderfully (great tones; no dots) with Cone inks
> come our muddy and blotched with MIS.
> I fiddled with the gamma in the piezo driver but that didn't help.
> Any suggestions?
> Thanks -- Stephen Smith
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and other resources as they are often being updated. The page is at:
> - Good manners are required at all time. No personal attacks or "flames."
> - Before posting a question, search the message archives and the various resources on the homepage.
Re: Trouble with Piezo and MIS
2002-05-11 by ruhrfoto
Stephen,
when I switched from the PiezoDriver/Cone-Ink combo to the
PiezoDriver/MIS-FS-Ink combo on my 1160 I had to readjust all
my gradation-curves a bit - it was not a big deal.
I printed a 21step wedge step and customized the greyscale
settings in PS 6.0 for the new ink.
From now on I had WYSIWYP on my monitor. Tonality of my
prints was equal to the old Piezo-prints. I could only tell them
apart by judging the slight difference in overall tone (slightly
warmer with cone inks or vice versa: slightly cooler with MIS FS).
Nothing about "muddy" prints at all.
There seems to be something wrong with your settings.
Did you print the 21 step greyscale wedge??
Bernd
--- In DigitalBlackandWhiteThePrint@y..., Jerry Olson
inkset.
> Jerry
> sdsmith9999 wrote:
> > Hello group:
in my 1140
> > with Cone inks.
dots
> > are too visible.
Cone inks
help.
> > Any suggestions?
subject header.
or "flames."
2002-05-11 by sdsmith9999
Thanks, folks, for the help.
I'm having trouble with the Roark curve too.  A 21 step test strip
looks really compressed.
I'm not a whiz at this stuff.  Cone/Piezo worked well, but that was
on my previous computer. So I'm wonding about my settings upstream of
the Piezo driver.  What, in general, should I do in the color space?
And what else might I be doing wrong (a lot, probably)?
Stephen
2002-05-12 by jrandall1149
--- In DigitalBlackandWhiteThePrint@y..., "sdsmith9999"
of
space?
Stephan:
The Roark and Randall workflows are very fussy about colorspace,
gamma, color correction on or off, etc.  You must follow the recipe
exactly.
Speaking for the Randall workflow:
1) you should have your monitor set to gamma 2.2 and edit your image
in gamma 2.2 space
2) If your image is not already in AdobeRGB 1998 (a gamma 2.2 space)
then convert your image to AdobeRGB.
4) Use No color correction (Set it in the Epson properties dialog)
5) Set your print driver to Color space: same as source (PS6.0) or
Space:Abobe RGB (PS5.5)  Uncheck printer CM.
5) Check all other setting in the workflow document.
6) EAM paper (or similar)?
The 1160 driver sometimes does not register changes in the Advanced
properties box--after setting and hitting OK, hit the advanced button
again and then OK.  This seems to work (at least for me).
Version E workflow is for the reformulated FS inks (since abut
January 2002 )If you bought your FS inkset before then, try the
Version D workflow.
Double check to make sure your inks are in the correct positions.
Print out a purge file.  Dark gray = cyan position  Middle gray =
magenta position  Light gray = yellow position.
Good Luck.
Jeff Randall
of
space?
Stephen:
After sleeping on it, I'd like to add that you should also make sure
to remove any monitor correction (dot-gain curves) you implemented
for PiezoBW.  You need a monitor calibrated to 6500K and gamma 2.2
with properly set b/w points--a plain vanilla calibration.  In
general, images that have been optimized to print with the PiezoBW
driver, will not print well using the Epson driver unless you apply
another transfer curve to "undo" the PiezoBW optimizations.  I think
Robert Morrison has posted several messages in this group on this
topic (and probably others--sorry if I forgot you).
Jeff Randall
