Taking apart printers/ultrasonic cleaning
2002-05-26 by Keith Cooper
Hello
Some time ago I was given a dried up Epson 800. With nothing to lose I
removed the heads and after soaking them in a 5mm deep pool of Isopropyl
alcohol for a few hours, put them in an ultrasonic cleaning bath (I use it
for mapping pens and lend it to friends for jewellery :-))
I also used a small syringe and some tubing to force alcohol through the
jets
After a few minutes of zapping in the bath, they were dried and put back in
the printer - and worked fine (and continue to do so)
Was I lucky that they still worked?
How robust are the heads?
There were no alignment problems afterwards, they seemed to fit back in very
positively.
bye for now
Keith Cooper
Re: Taking apart printers/ultrasonic cleaning
2002-05-26 by jimhayes361
I'm glad you got it to work. I also know that a similar procedure is
outlined by a MIS customer on their site. Here is what I know, from an
 Epson 760 tech repair manual:
Page 78 thru 88, roughly, are devoted to aligning/ realigning the
printhead with special software, licensed only to Epson repair techs
(I tried to buy a copy, then beg one<g>), and only running on Windows
98 thru the LPT port. This is a signifigant fraction of the manual,
which shows you how to take apart and build a 760 from pieces. BTW,
the software is designed for not only the 760, but the 860 and the
1160 as well.
You have to do something called a "Printhead Angular Adjustment" and a
"Bidirectional Adjustment". If you install a new printhead, you also
must do an "Initial Ink Charge" followed by inputting a "Printhead
Voltage ID" into the software. If you remove more things like the
carriage unit, there are more adjustments.
The software also lets you reset the waste-ink counter, which counts
how many times the printer has gone thru cleaning cycles. After a very
huge number, the printer is programed to disable itself. Not many
people know this, so don't do excessive cleanings<g>
The software also can check info on the "USB ID" and "Market
Destination". I think this latter keeps track of where the printer was
orignally meant to be sold.
The alignments can be easily done with printouts, a screwdriver- but
you need the software too. As to whether the alignments are really
needed or not-you'd have to make up your own mind.
Jim H.
--- In DigitalBlackandWhiteThePrint@y..., Keith Cooper
<yahoogroups@n...> wrote:
> Hello
I
Isopropyl
use it
> jets
back in
in very
> positively.
> bye for now
> Keith Cooper
