1200 born again with FS-N ink & scanner-based curves
2002-06-09 by Barry Kelsall
My 1200 sat idle as I preferred the color output I was getting from my 1160. I liked the B/W images I was getting from the original MIS Quads, especially on Legion Photo Matte, (also from an 1160) but I wished for a cooler look, hopefully using EAM. So I pulled my 1200 Gen 3 CIS & installed a CFS with the MIS Full Spectrum Neutral hex set - the version for the native Epson driver. I like the fact that the Epson 6-color driver already partitions the ink channels (black, cmy, & light cm). So I only needed to make a simple Curve adjustment to profile the paper, but I don't possess a spectro or a densitomiter. My little Epson 1640 scanner would have to do. I made my own test target in PS7 consisting of a smooth 0-100% gradient next to a 12-step posterized copy of the gradient. I printed this using the Back Light Film setting & no color adjustment in the Epson driver, then scanned it in the 1640, using high-bit grayscale and a gamma of 1.5 with color adjustment turned off. Back in PS7 I used Levels to set the white and black points of the scan to 0 and 100 (both original & printed targets need to have the same range of values- we want a smooth ramp within the ink's tonal space), and then I proceeded to record the K values for each step of the original and the scanned targets. I used those values to plot points in an adjustment curve, using the scan values as input and the original target values as output. I then repeated the process, this time printing the original target with the new adjustment curve applied. I then made "best guess" adjustments to the curve. It took about five iteratioins to dial the numbers in. I couldn't get the target values to match exactly, but the prints do seem to be a fairly close match to what I see on the screen (PhotoCal 2.6 & Spyder calibrated NEC FE950+ on a Win2K system). Interestingly, all of the curve points are only a 1% change until an input at 97% & output at 94% to compensate for Epson's blocking up of the shadows in the 1200 driver. I realize I am relying on a linear response from the little scanner to make this work. It was helpful that the inkset performs quite well on its own with the Epson driver (again, Back Light Film & No color adjustment). Depending on subject matter, some folks may be quite happy printing without any curves at all. -BK
