How many prints per ounce (MIS-VM/Epson 1280)?
2002-06-20 by kd7mw
A couple of very un-artistic questions.
- About how many prints (8x10 or 8.5x11) do you get from one set of
cartridges of MIS VM inks for the Epson 1280?
- How many ounces of ink are there in a cartridge (of black, and of
the gray/color chambers)?
- Anybody want to share experiences/horror stories from when you
decided on either refilling cartrigdes or getting a CIS system?
- I also have an old HP Deskjet 500 that works well.  Is it worth the
bother hooking the Deskjet and the 1280 up to an A/B box so I can use
the Deskjet for ordinary text printing and the occasional music
manuscript?  This is a cost of ink vs. convenience thing.
Why I'm asking all this:  I just ordered a set of prefilled VM
cartridges for the 1280 from MIS to try out Hextone printing.
Eventually I may get the virgin cartridges and refill myself, or get
a CIS.  I don't print every day, and I might not print every week
except for a quick throwaway to keep the ink from drying out.  I need
this information to get an idea of how much ink I'll consume, etc.
--Peter Klein
Seattle, WA
Re: How many prints per ounce (MIS-VM/Epson 1280)?
2002-06-23 by jimhayes361
I'll pass on that one.
Each chamber is 18ml (0.61 oz), including K...but chip is designed to
not empty cart fully so you don't use it all up- unless it's a
CIS/CFS..
I just updated my vacuum fill instructions for carts yesterday and
Martin was kind enough to convert it to pdf format. I'm finding that
the chips and connector in printhead are very delicate and caution in
handling/ installing chip is mandatory. See the files section for cart
fill file.
use
I don't use an a/b switch because Epson doesn't recommend it and I'm
conservative. But, MANY many people have had luck with it, this
question has been asked before in the archives.
I ordered only one "prefilled" set once. What was strange was one of
the color positions ran out of ink way before it was supposed to, as
if it had not been completely filled. I have not heard of others
having this problem, it was a freak. Still I fill my own. I will go to
CFS after my vacation.
You sound like me. My color carts last three weeks unless I've been
printing a lot for a show, the K cart maybe 3-4 weeks.
I've been finding that one of the most important things is to run a
quick draft purge print that doesn't use much ink often, maybe once a
day more or less.
I found that humidity below 35% seems to encourage clogs, 40%RH is
better. Recently I find a possible correlation between temperature as
well- it "seems" as if I get more clogs if temperature is above about
76-77 degrees F. 68-70 is ideal it tentatively looks like. Not proved.
  I
need
I calculated that if you fill a set of carts with hex VM it will cost
you about $26 (half of a prefilled set bought from MIS)for the set not
including initial investment like fill kits and chip resetters. It
takes me a leisurely 3 hours to do a set but you can trim that to
about 2 1/4 hours maybe. And some of that 18ml of ink gets thrown away
with the spent cart. A CIS/CFS is much more economical, but there are
some good reasons to fill virgin carts instead.
Jim H.
> Thanks,
> --Peter Klein
> Seattle, WA
2002-06-24 by kd7mw
Jim: Thanks very much for the info on refill cartridges vs. CIS.
At the end of your message, you mention that even though CIS in the
long run costs less than refilling cartridges, there are still
reasons to go with refills.  Would you elaborate further?
Also, how many times can you refill a cartridge before you need to
discard it and buy a new one?
--Peter Klein
--- In DigitalBlackandWhiteThePrint@y..., "jimhayes361"
cost
not
away
are
> Jim H.
2002-06-24 by jimhayes361
I can't ever make an argument for carts being more convienent or
cheaper. In situations where you are testing different inks and want
to switch quickly from one to another, carts are better than CIS. If
you are having trouble with one inkset, and you want to run printing
test, merely filling up carts instead of using a CIS/CFS is of course
wise too.
There are a couple of issues with CIS/CFS that you don't get with
carts. One problem is that the CIS "carts" can work themselves up over
time since they are not held down by the grey cart clamps. MIS has
addressed this with modified cart clamps for $10 that exert downward
pressure on the CFS yet still allow tubing to clear the grey clamp.
The other problem that some people report is that the tubing is
permeable, and the k ink especially is prone to evaporation and so
drying up.
My own personal take on all this is that I'm probably going to go CFS
in a month or two, and use the cart clamps and MIS's new f16 resetter
which is roughly 1/2 price of the read only CIS chips. Since MIS CFS
is so cheap and parts are available, I'll toss the tubing/cart/ink
every 4-6 months, and replace, along with ink.
On the We-Ink site they think refills are possible. MIS doesn't
recommend it. I have never refilled, I've always used virgin carts so
I'm not qualified to comment.
Jim H.
> Thanks,
> --Peter Klein
