Re: [Digital BW] Different ink usage...
2002-07-01 by Martin Wesley
Sent: Sunday, June 30, 2002 4:59 PM
Subject: [Digital BW] Different ink usage...
> I've been using MIS VM-Inks with a MIS CFS for a while now. Very good
> results. But I've been noticing that the black ink bottle empties MUCH
> faster then the other three.Actually,the other three are almost at the
same
> level since I started...
> The lines are feeding normally when I run cleaning cycles or turn the
> printer on,,I'm printing RGB files with the driver's "Color" setting.
What\ufffds
> up?
Andr\ufffd,
Probably nothing. The inks just don't get used up at the same rate. I find I
use Black and Yellow more quickly than the others. Very dependent upon the
general nature of your images and your personal tastes in printing them. I
would not be concerned about it if you are happy with the results you are
getting.
Martin
Martin Wesley
http://www.borderless-photos.de/guests.html
