--- In DigitalBlackandWhiteThePrint@y..., Bernhard.Schuerlein@t...
wrote:
> Hello,
> I started to hang b&w prints (MIS VM ink) on my walls and found the
glass to be a problem: Antireflex glass is not transparent enough
I have a framing book that mentions as an aside that it is created
with an acid etching- and therefore they say it is not as archival as
regular or conservation clear glass. Interestingly, anti-glare plexi
doesn't have this problem- but my book says for papers that tend to
flake, using plexi is a no no (static charge causes lots of dots to
build up).
I'm just going by what my framing books say on the subject...
reflex glass has way too much reflexions from various angles, the very
best is without glass at all.
> What does this mean for the longevity of a) the print and b) of the
passepartout. It is a normal (dry) living room, no direct sun.
I did some tests where I put two test strips in a light -tight box.
One was sprayed with Lumijet Imageshield (3 coats). there was a
difference in the "warming" of the strips after variously, one to five
weeks, depending on the ink (Piezo or MIS FS, VM) and moreso on the
paper (EAM seemed the most stable). In all cases the unsprayed strip
was noticably warmer. I didn't compare either to a freshly printed
strip as a control however.
Humidity ranged from 30-40%RH, temperature from about 66 degrees f to
81 degrees f.
> Would a kind of "anti UV" spray be useful?
For me on all the papers I tested it certainly did whether in the
window or the box.
Do you recommend to put
the prints behind glass in any way?
I now use conservation clear glass. I figure I can use all the help I
can get. A nice frame will also help seal out pollutants, etc. There
is a paper on lightfastness of color prints which applies a lot to b&w
prints in the files section of this list that I submitted quite some
time ago. It is well worth the read.
Jim H.
> Thanks for answering,
> Bernhard
