Brightcube semi matte
2002-07-11 by André Vallejo
Brightcube semi matte is a nice paper.But it has one major problem.When you look at the print front-facing,90 degrees,it's ok. If you look at certain angles,the reflection of light on it makes it very odd-looking! This does not happens with matte papers or glossy ones.I tried spraying it but it does not help. Any hints? Andre
2002-07-11 by Robert Morrison
This is called bronzing...you are not spraying enough...how many coats what are spray are you using? Bronzing is gone for me with semi-matte (and other semi-gloss papers, eg., Kodak Ultima) after one coat of spray...but I spray with 4 light coats to increase dmax further and to make sure the pigment is sealed. Semi-matte performs identically with respect to this as all of the other semi-gloss/luster papers that I've tried. Gloss papers typically bronze even worse...what inks set are using? I've used MIS FS-N inks in the past...but I'm getting stunning results with the Piezotones. Robert PS I submitted a sprayed semi-matte print in the July DigitalBW print exchange...if you know anyone on that list you can see it.
On 7/10/02 6:33 PM, "André Vallejo" <avs@...> wrote: > Brightcube semi matte is a nice paper.But it has one major problem.When you > look at the print front-facing,90 degrees,it's ok. If you look at certain > angles,the reflection of light on it makes it very odd-looking! This does > not happens with matte papers or glossy ones.I tried spraying it but it does > not help. Any hints? > Andre > > > > Please visit the Group Homepage to check the Files, Bookmarks, Polls and other > resources as they are often being updated. The page is at: > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > Please follow these basic guidelines: > - Include your full name with your message. > - Include the address of your website, if you have one. > - As threads develop, trim off excess portions of earlier messages to keep > them short. > - As the topic of a thread changes remember to change the subject header. > - Good manners are required at all time. No personal attacks or > "flames." > - Complete your Yahoo profile. > - Before posting a question, search the message archives and the various > resources on the homepage. > > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > >
2002-07-12 by André Vallejo
Well,I spayed two coats.It\ufffds not Krylon,is a local brand I found (no Krylon around in Brazil...) I use VM-MIS. Odd,isn\ufffdt it...? Andr\ufffd Message: 5 Date: Thu, 11 Jul 2002 09:41:07 -0700
From: Robert Morrison <rmorrison@...> Subject: Re: Brightcube semi matte This is called bronzing...you are not spraying enough...how many coats what are spray are you using? Bronzing is gone for me with semi-matte (and other semi-gloss papers, eg., Kodak Ultima) after one coat of spray...but I spray with 4 light coats to increase dmax further and to make sure the pigment is sealed. Semi-matte performs identically with respect to this as all of the other semi-gloss/luster papers that I've tried. Gloss papers typically bronze even worse...what inks set are using? I've used MIS FS-N inks in the past...but I'm getting stunning results with the Piezotones. Robert
2002-07-12 by Stan McQueen
At 10:41 AM 7/11/2002, Robert wrote: >This is called bronzing...you are not spraying enough...how many coats what >are spray are you using? Bronzing is gone for me with semi-matte (and other >semi-gloss papers, eg., Kodak Ultima) after one coat of spray...but I spray >with 4 light coats to increase dmax further and to make sure the pigment is >sealed. Semi-matte performs identically with respect to this as all of the >other semi-gloss/luster papers that I've tried. Gloss papers typically >bronze even worse...what inks set are using? I've used MIS FS-N inks in the >past...but I'm getting stunning results with the Piezotones. What spray do you use? Stan ================================ Photography by Stan McQueen http://www.smcqueen.com
2002-07-12 by Robert Morrison
On 7/12/02 7:20 AM, "Stan McQueen" <stan@...> wrote: > At 10:41 AM 7/11/2002, Robert wrote: >> This is called bronzing...you are not spraying enough...how many coats what >> are spray are you using? Bronzing is gone for me with semi-matte (and other >> semi-gloss papers, eg., Kodak Ultima) after one coat of spray...but I spray >> with 4 light coats to increase dmax further and to make sure the pigment is >> sealed. Semi-matte performs identically with respect to this as all of the >> other semi-gloss/luster papers that I've tried. Gloss papers typically >> bronze even worse...what inks set are using? I've used MIS FS-N inks in the >> past...but I'm getting stunning results with the Piezotones. > > What spray do you use? > Krylon UV Resistant Clear (#1305). Its available in a large can for about $5 from many art supply stores (e.g., Utrect, Pearl, etc.). I put down four light coats about 10-30 sec apart (depending on drying conditions). You need good ventilation. There is a large amount of information in the archives on gloss/semi-gloss papers and spraying. Search under the word gloss and brightcube. I started a thread called Glossy Paper Screen. Robert
> > ================================ > Photography by Stan McQueen > http://www.smcqueen.com > > > > Please visit the Group Homepage to check the Files, Bookmarks, Polls and other > resources as they are often being updated. The page is at: > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > Please follow these basic guidelines: > - Include your full name with your message. > - Include the address of your website, if you have one. > - As threads develop, trim off excess portions of earlier messages to keep > them short. > - As the topic of a thread changes remember to change the subject header. > - Good manners are required at all time. No personal attacks or > "flames." > - Complete your Yahoo profile. > - Before posting a question, search the message archives and the various > resources on the homepage. > > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > >
