Scanning B&W 35MM Negatives using Nikon Super CoolScan 4000-Paul's idea.
2002-07-22 by André Vallejo
I tried Paul's method of using the slide setting in the Coolscan 4000.Ended up with totally washed out scans,a lot worse then with the normal settings.Any special trick Paul? Andr\ufffd
2002-07-22 by Paul Roark
Andre, It may be that the 8000 has a different driver/software package than the 4000. When I use the "positive" setting for B&W negatives, the image will look very light when inverted in Photoshop. The default algorithm Nikon uses gives tremendous shadow separation -- probably too much. I have tried raising the histogram middle (gamma) in the Nikon tools palette and comparing that to doing the same thing in Photoshop, and I'm not completely sure if there is any difference. I think I may have detected a little, but it's not dramatic. Nonetheless, just in case there is an advantage, I do raise the middle of the curve on the Nikon tools histogram graph in order to compress the shadow tones. I tried, again, comparing the "negative" setting to the "positive" setting and found that to get the highlights in my B&W negatives I needed about -0.6 analog gain adjustment. (This varies with each negative.) However, the shadows were blocked in the negative I just tried. Even though the blackest black read only 96% in Photoshop, there were masses of 96% where in the "positive" scan there was lots of detail & information. What I look for is a 14 bit scan that has enough room off the ends of the histogram that when I move the PS levels histogram slider in with the alt key held down to tell me what pixels are where, I get no pixels lighting up at 100% or 0%. I want just a hair of space to be sure nothing has been lost. So, with a scan like that, even if it looks too light when inverted in PS, the PS image adjustment curves brings the values closer to what I like (and what looks more normal), and there are enough g/s values left to do any manipulation I want and still have a full 256 levels left by the time I get to the printing stage. (I do now use the Nikon tools histogram to pushed up the middle of the curve to compress the dark tones.) (I have not yet experimented with other than the Nikon default profile in the "preferences" section of the driver.) Paul http://www.PaulRoark.com ________________________________________
Sent: Monday, July 22, 2002 10:15 AM
Subject: [Digital BW] Scanning B&W 35MM Negatives using Nikon Super
4000.Ended
André
Yahoo! Groups Sponsor
ADVERTISEMENT
them short.
- Good manners are required at all time. No personal attacks or
"flames."
resources on the homepage.
[Non-text portions of this message have been removed]2002-07-22 by Jerry Olson
did you use the full range setting? IS there a full range setting in that scanner? jerry Andr\ufffd Vallejo wrote:
> > I tried Paul's method of using the slide setting in the Coolscan 4000.Ended > up with totally washed out scans,a lot worse then with the normal > settings.Any special trick Paul? > Andr\ufffd > > > Please visit the Group Homepage to check the Files, Bookmarks, Polls and other resources as they are often being updated. The page is at: > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > Please follow these basic guidelines: > - Include your full name with your message. > - Include the address of your website, if you have one. > - As threads develop, trim off excess portions of earlier messages to keep them short. > - As the topic of a thread changes remember to change the subject header. > - Good manners are required at all time. No personal attacks or "flames." > - Complete your Yahoo profile. > - Before posting a question, search the message archives and the various resources on the homepage. > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
