Re: [Digital BW] Anybody using the Nikon D100 yet?
2002-07-28 by Kip Babington
I've had one for about 3 weeks and am loving it (after 30 years of film
Nikons from F to F3 to F100.)  There is an extensive review at
www.dpreview.com if you're not familiar with all the little details.
The camera is doing what I got it for - capturing my daughter on a horse
in midair over a jump, something none of the lesser(non-SLR) digital
cameras I've seen could do.  It also does a wonderful job in all the
other   The D100 seems just a responsive as my F100 in actual use - turn
on is instantaneous, shutter response is near instantaneous, and the
buffer is big enough that I've never had to wait for an image to be
transferred to the card before taking the next one.
Before I got it I hadn't thought about how liberating it is not to have
to rewind and reload film every 36 shots.  But now I no longer face the
dilemma of to-reload-or-not when the film counter reads 24 and my
daughter is about to enter the ring for a 10 jump round and, if she
makes it over all jumps cleanly, will stay in the ring and start a 6
jump jumpoff round before I could rewind and reload.  If I reload I
waste 12 frames of film, but if I don't and she makes the jumpoff I
won't have enough film to capture each jump.  With the D100 I don't even
think about it - I just keep shooting.  (Along this line, battery life
seems to be exceptional - I've not come close to exhausting a battery in
the course of a day's shooting, although I don't do much image viewing
while I'm shooting which probably saves a lot of power.)
I do have a 10 GB ImageBank, basically a battery powered hard drive with
slots for CF and SM cards.  Stick a card in and press the button and it
downloads the images from the card to the disk, so you can wipe the card
  and go back to work.  Later you dump the Image Bank to your computer
via USB cable.  There's always a break in the action somewhere that
allows time to transfer things to the Image Bank, and a small second CF
card will keep me going for a while if things pick up before the image
transfer from the main card is complete.  I have the D100 set to number
frames sequentially, so even if I swap cards several times throughout
the day the images will all be in sequence when they're dumped into a
single folder on the computer.
I posted a comment last week about my sterling results producing a B&W
print of a D100 image using a Canon S9000 printer with its standard (6)
inks.  As I said there, it was as fine an image as I've ever made in my
darkroom, and far better than most.  Just for fun, the other day I blew
the image up to 13x19, the largest size the printer will do, then took a
7.5 x 9.5 chunk out of the middle of it (I don't have any large inkjet
paper on hand, but plan to remedy that tomorrow) and printed the result
- again just sent it to the printer using its high quality settings.  I
am even more blown away by the quality with this larger print, and
cannot imagine that I could have done as well with film.
As to old manual focus lenses, they will fit, but can be used only in
manual exposure mode.  You do get focus confirmation, but no other
automation.  The instruction manual talks about "CPU lenses" which
reminds me that there is a fellow who will add a CPU chip to some AI and
AIS lenses (not all of them have room to fit a chip in, apparently) and
as I recall the charge was under $100, so if you have a favorite old
lens that you don't need autofocus for, it might be worth having it
"chipped" rather than replace it with a new AF model.
The feature I would most hope for on the next generation of Nikon D-SLR
is a full frame sensor, so that my wide angle lenses will give the wide
image I paid for.  On the telephoto end, my 80-200 becomes the
equivalent of a 120-300, which is fine for most situations.  But on the
wide end, at the moment the widest lens I have is a 20-35 zoom, which on
the D100 is equivalent to a 30-52 or so on a film camera.  To get the
equivalent of 20mm coverage on the D100 I will need a 14mm lens, and
they ain't cheap.  So my hopes are for the D-2/D-200 (when they come
out) to have a full frame chip.  If I start saving now I might even be
able to afford one when it's finally available.  ;-)
You do have to think differently about organization and storage of
images in digital form, but there are lots of software options out there
to accomplish these tasks.  It's the thinking differently that takes a
bit of adjustment, but after a couple of months in the digital world I
think I've got a handle on this aspect of the process.
On the whole, I will not be surprised if I go from shooting 200 rolls of
film a year to 10 or less, with the rest of my photography being done
digitally.  I still have much to learn about using Photoshop, but have
learned enough in 3 months to get decent glossy B&W results without
having to spend a lot of time on each image.
Hope this helps.  I don't know what the D-100 availability is at the
moment - my store got about 10 in at once and all had been sold in
advance (I think I got the first one) and I think the next 10 they get
are also spoken for.  But at least they are being shipped.
Kip
> Reviews? Comments?
> Can I use my trusty old Nikon glass on the D100 body?
> Am seriously thinking about giving it a go!
2002-07-28 by Bob Frost
Probably because of your first sentence!
Bob Frost.
> The full frame chip is coming, for the D100 and Canon D60.
> Anybody know why NObody is making an 8 or 10mm Wide angle lenses just
> for Digital cameras?
2002-07-28 by Jerry Olson
Kip, The full frame chip is coming, for the D100 and Canon D60. They
have to hold something back so they can sell a new and improved camera
every 18 months! Can hardly wait for the full size chip D120.
And then there's the Foveon chip about to make its' Debut....
Jerry
> Y
Never thought about that, but you're very likely correct. I imagine none
will be necessary with the full frame chip. So now we just have to wait
another 18 months.
Jerry
2002-07-29 by Robert Morrison
Contax new 35mm digital is full frame...just played with one the other
day...feels kind of plastic...not nearly as solid as my D1x.  Their medium
format digital is like a load of bricks in comparison...you'd need to weight
train to use this camera hand held.
Everybody I know uses the Sigma 14mm/f2,8...that only gets you to "21mm"
though.  I like this lens on my D1x...but it is huge in comparison to my old
nikon 20mm/f2,8.  I think nikon has a 7mm fish eye...that will run you about
$4K used...but its a fisheye.  I don't believe that anyone makes a full
frame under 14mm for 35mm SLR's.  This is one major problem for pro digital
rigs...but I imagine that in the next round of pro cameras (maybe not the
prosumers like the D60 and D100 though...that would be an obvious
distinction for Nikon and Canon to make).  I'd imagine that we will have a
major Nikon announcement in the fall...but maybe not shipping until spring.
Robert
> another 18 months.
> Jerry
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and other
> resources as they are often being updated. The page is at:
> page.
> them short.
> &amp;amp;quot;flames.&amp;amp;quot;
> resources on the homepage.
