RE: [Digital BW] Digest Number 883
2002-08-06 by Frank Vena
hi martin,
thanks for responding. no i haven't tried it with high speed off but i will
right now and let you know what happens.
Frank
____________________________________________________________________________
_____________
Message: 25
   Date: Mon, 5 Aug 2002 14:44:18 -0700
Subject: Re: Re: banding problem
Frank,
I did look at your image and I have ever encountered anything like that.
This was printed from a patch generated in PS so there are no issues of
scanning problems, etc. Does it occur if you print the same patch with all
the inks?
The only think that comes to mind is some mechanical problem that is causing
the side to side head speed to vary.
Does the problem change if you turn "High Speed" on or off in the driver
settings?
Martin Wesley
http://www.borderless-photos.de/guests.html
Sent: Monday, August 05, 2002 1:21 PM
Subject: [Digital BW] Re: banding problem
> hi again, i have to re-post this request since i got no responses the
> first time around and am in desperate need of suggestions. thanks in
> advance for your insight to this problem.
> Frank
> --- In DigitalBlackandWhiteThePrint@y..., Frank Vena <frank@f...>
> wrote:
> > i have a new problem now. it's a banding problem on my Photo 870,
> printing
> > grayscale images with the black ink only. not the typical
> microbanding from
> > clogged nozzles or misaligned print heads (i've had enough of those
> to
> > recognize them). no, this one is one i've never seen before. it is
> wide
> > banding that occurs only in the 1/4 tones and runs perpendicular to
> the
> > direction the print heads print. i've posted a scanned print of a
> 1/4 tone
> > patch that shows this phenomenon quite clearly (after a curves
> adjustment to
> > increase contrast for viewing purposes).
> > can anyone take a look and tell me what might be causing this? the
> jpeg is
> > posted at:
> > http://www.frankvena.com/banding.jpg
> > much appreciated. and thanks again for the help with the clog that
> ate
> > Vancouver!
> > Frank Vena
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and
page.
them short.
&amp;amp;quot;flames.&amp;amp;quot;
resources on the homepage.
well, i tried printing the image with high speed off and the banding is
almost completely gone. it's gone enough to be not noticeable unless you
knew it was there to look for. so that solved the issue but any ideas what
the base problem would be that would cause that when printing at high speed?
Frank
_____________
hi martin,
Frank
_____________
Message: 25
Frank,
the inks?
settings?
Martin Wesley
> Frank
> printing
> microbanding from
> to
> wide
> the
> 1/4 tone
> adjustment to
> jpeg is
> > posted at:
> ate
> > Vancouver!
> > Frank Vena
page.
them short.
