1280 feeding problem
2002-08-28 by bggilliand2001
Just finished a run of about 50 sheets of 11x17 308g photorag and now
my 1280 refuses to feed paper of any sort. It just keeps trying to
feed and then times out with "error to printer" message. I've got a
support behind the last sheet of paper, and I've tried to print with
and without the feed support. Any suggestions? Any way to get
more "grip" on the paper. Thanks
Barry Gilliand
Re: 1280 feeding problem
2002-08-28 by janishilesh
Barry,
I too have often had such problems when using thick papers like PR
308 gsm, and BC Satine 300 gsm. The coating seem to slip, and the
feed mechanism does not get enough traction.  I jsut turn the printer
off for a while, and then feed epson photogloss (not the premium one)
through the system. Tacky papers such as HP gloss also works well.
Good luck.
Shilesh
--- In DigitalBlackandWhiteThePrint@y..., "bggilliand2001"
now
with
> Barry Gilliand
2002-08-28 by tomoc
That's the draw back to all of the fine art papers on desktop
printers... They are "dusty" and gunk up the feed mechanism and print
heads if you don't do a little maintanence as you go...a few extra
nozzle checks and cleaning cycles and occasionally run alternate
paper through...the old epson list had some other tricks for cleaning
paper feeds if you really get into a jam (list is dead but still
searchable).
Tom O'Connell
TomOC@...
www.thomasoconnell.com
--- In DigitalBlackandWhiteThePrint@y..., "janishilesh"
<shilesh.jani@s...> wrote:
> Barry,
printer
one)
> Good luck.
> Shilesh
> now
to
a
> with
> > Barry Gilliand
