Re: [Digital BW] How Would I Know If My Scanner Is Good Enough?
2002-08-29 by CDTobie@aol.com
In a message dated 8/29/02 9:15:35 AM, jon.judson@... writes: >I'm giving a lot of thought to trying digital printing, most notably >the Epson 2200. I do mostly large format work (4X5) and some 35mm, >generally all black and white. > >I've been scanning my negs into a Microtek ScanMaker 4, using >negative trays, and playing with them in Photoshop. Problem is, I'm >not sure whether the resolution of my scans are good enough for >printing digitally. 600 dpi will give you 600 pixels across the page, which for an 8 by 10 will be less than a hunderd dpi, and certainly not up to anybody's standards. From 4x5 the ratios will be much better, but despite the alleged d-max you may still have trouble with the range of chromes, and if you can't get highbit out of the scanner you may also have trouble with negs. One of the Epson scanners would be a better compromise for affordable scanning. C. David Tobie Design Cooperative CDTobie@...
