Re: [Digital BW] Re: ImagePrint and Custom Profiles
2002-09-03 by Martin Wesley
Sent: Tuesday, September 03, 2002 12:09 PM
Subject: [Digital BW] Re: ImagePrint and Custom Profiles
> --- In DigitalBlackandWhiteThePrint@y..., "Dan_Honemann" <
> dan_honemann@y...> wrote:
> > Does a RIP like ImagePrint obviate the need for custom printer/paper
> > profiles, or do the two work in tandem?
> You can build custom profiles if you like. If you use a paper that isn't
> supported, you'd want to do this (although the RIP comes with a target
that
> you can output and send to ColorByte and they will create a profile for
you).
> For grins I build a custom profile and it worked just fine. I simply
opened the
> target from ProfileMaker Pro (the new 9.88), set the RIP so it would not
use an
> output profile, measured and loaded the new profile.
Was this for a grayscale ink set? Do you think ProfilerPro would be up to
the task with grayscale?
Martin Wesley
2002-09-03 by thedigitaldog
--- In DigitalBlackandWhiteThePrint@y..., "Martin Wesley" <
No, full color. I can't think of any software off hand that allows one to make a
true grayscale profile. We need that. ProfileMaker Pro allows you to make a
CMYK profile, then save out just the information about black channel and end
up with a grayscale profile but that's not going to fly. I'm meeting with a few
companies next week at Seybold that make profile software and on the top of
my list is the ability to make a true grayscale profile.
The profiles from ImagePrint are made using ColorByte's own profile software.
They will make you a profile if you wish (and I think it's free). They supply a
target (grayscale as well). I was told they are considering selling this profiling
package which would be a solution for building profiles for the gray inkset.
Sent: Tuesday, September 03, 2002 2:04 PM
to
make a
a
end
a few
of
software.
supply a
profiling
inkset.
I was afraid you would say that. I am very happy to hear that you will be
carrying the word to Seybold on the issue. It certainly needs to be
addressed. While the B&W market is small I suspect that once the tide does
shift and silver printers start moving to digital in large numbers it might
prove lucrative. Especially to those who got in early.
I am sending out some targets to Colorbyte today but I was curious to know
if I had a shot at doing anything with my own resources.
If Colorbyte makes the profiling capability available then they really will
top the competition in the grayscale market.
Martin Wesley
2002-09-04 by CDTobie@aol.com
In a message dated 9/3/02 5:59:46 PM, mwesley250@... writes:
>I'm meeting with
>a few
>top
>of
The problem is that, like a CMYK profile, a Gray profile is a device
description. If that device is using Small Gamut CMYK inks, then a standard
RGB or CMYK profile can do a good job defining the device, depending on what
profiling package is used. For devices running various neutral gray inks, or
a few of those and one or two toned inks for tonal adjustments, the current
methods of conversion to these colors is currently done by transfer curves
and other non-ICC processes. The idea that simply creating an ICC  Gray
profile will somehow automatically address such systems is impractical,
unless the ICC process were to be moved forward to an n-channnel system with
very sophistocated channel interactions.
What would actually be needed would be driver or RIP controls for several
grays, similar to the current light and dark C&M controls in some RIPS, as
well as seperate tonal controls for any toning colors, and linearization ramp
targets and input to define these controls. Unless a standard system was
chosen, and ICC standards for defining the process developed, this could not
be turned into something universal like a gray profile.
C. David Tobie
Design Cooperative
CDTobie@...
2002-09-04 by thedigitaldog
what
In the case of ImagePrint, its really neither. ImagePrint uses 6 of the 7 inks to
print in its monotone mode. I guess one could try setting the yellow ink limit to
zero and building a "standard" RGB output profile. Don't know if that would fly
or not. I do know that the target supplied by ColorByte for building a "monotint"
(grayscale) profile has no color patches but uses 6 color inks. Go figure.
From what I've seen, I'd simply stick with the supplied profiles for printing
Monotint. The output is that good. If I had a paper not supported, I'd print it out
and send to ColorByte for a profile. For color output, I've seen no reason to
treat this product any differently with regard to making profiles. The color
profile to Matt paper using ProfileMaker Pro was great.
2002-09-04 by Martin Wesley
David,
Thank you for all the good info on ICC standards and profiling. Sounds like
Seybold might want to consider the idea of a standard for profiling
grayscale ink sets. I understand the problem and I guess profiling a
grayscale inks are more akin to the offset printing technology of quality
quadtone printing. I have to feel that the technology is there if someone or
group wants to devote the time to it.
I still find it fascinating that in the digital world there has been this
complete reversal between Color and B&W, and that quality B&W printing is so
much more difficult than Color printing.
Martin Wesley
http://www.borderless-photos.de/guests.html
Sent: Wednesday, September 04, 2002 5:40 AM
Subject: Re: [Digital BW] Re: ImagePrint and Custom Profiles
> >I'm meeting with
> >a few
> >top
> >of
standard
what
or
current
with
ramp
not
> C. David Tobie
> Design Cooperative
> CDTobie@...
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and
page.
them short.
&amp;amp;quot;flames.&amp;amp;quot;
resources on the homepage.
In a message dated 9/4/02 12:13:57 PM, mwesley250@... writes:
>like
>grayscale ink sets.
That would have to be taken up by the International Color Consortium; though
the color geeks that typically meet at Seybold would be a good group to
propose such an item to the ICC, if they chose to. Such standards move
slowly; so if you'd like to control your B&W in the next few year, you'll be
obliged to use proprietary methods instead.
C. David Tobie
Design Cooperative
CDTobie@...
2002-09-04 by tboleyyh
snip
standard
on what
inks, or
current
curves
system with
Exactly. Right, of course, as usual. The advanced and most succesful
B&W inkjet printing methods use 4 gray inks, or 3 plus a toner, or
some variation. Most people on this list are using such a system.
Charaterization of the device can be enormously useful, but does not
provide for the kinds of conversions required to make the most of
these inksets.
Color management can have no idea of the ideal way these inksets
should be put down on paper to their best advantage. It can be useful
to help determine what a device will do when those kinds of
manipulations are done though.
An ICC workflow wants to correct color (to put it blandly and overly
simple), quad printing has a different end goal. Since color
management can help us with dot gain etc. with different papers, for
one thing, it can be very helpful. But it needs to know what the new
"ideal" is to make use of a profile and take things the rest of the
way there.
Tyler
2002-09-06 by Dan_Honemann
Many thanks for the informative replies to my question.  Your
responses lead me to a second question (or maybe another way of
formulating the first): since Colorbyte provides free profiles for
papers to ImagePrint customers, does it make any sense for me to
invest in custom profiling software (and a flatbed scanner, neither
of which I own now)?  I also don't own a densitometer, if that
matters.  I intend to print both color and b&w on my 2200 using a
variety of papers.
Dan
--- In DigitalBlackandWhiteThePrint@y..., "thedigitaldog"
> profiles for printing Monotint. The output is that good.
> I've seen no reason to treat this product any differently
2002-09-06 by CDTobie@aol.com
In a message dated 9/6/02 10:22:14 AM, dan_honemann@... writes:
>variety of papers.
First off, a scanner-based printer profile is not likely to do justice to
your RIP and your 2200, especially for black and white. If ColorByte is
truely going to build free, unlimited, profiles for everyone who purchases
the low cost version of their RIP for the 2200, and if the profiles are
actual, accurate ICC profiles, then thats the way to go... but it seems
unlikely that they would. Wait until this shakes out before looking any
further, and if you end up looking, investigate spectro-based systems.
C. David Tobie
Design Cooperative
CDTobie@...
RE: [Digital BW] Re: ImagePrint and Custom Profiles
2002-09-06 by Andrew Biggs
I just got off of the phone with Colorbyte Software, and the unlimited
profiles rumor is definitely true. Apparently, they already have a very
large number of Epson and third party papers already profiled.
The software might be shipping on Monday, and the desktop version will
be $495. Currently the Epson 2200 is the only desktop printer supported.
-Andy
Sent: Friday, September 06, 2002 2:05 PM
To: dan_honemann@...; DigitalBlackandWhiteThePrint@yahoogroups.com
writes:
for
to
neither
a
	>variety of papers.
justice to
ColorByte is
purchases
profiles are
it seems
looking any
systems.
	C. David Tobie
	Design Cooperative
	CDTobie@...
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=233870.2307058.3723292.1793556/D=egroupweb/S=1705
019182:HM/A=1202766/R=1/*http://personals.yahoo.com>
I'm a Woman Man  seeking a Man Woman
Enter city or ZIP
Age:   to
 Show only ads with photos
Polls and other resources as they are often being updated. The page is
at:
wish to unsubscribe, please edit your Membership preferences by visiting
this same page.
messages to keep them short.
subject header.
various resources on the homepage.
	Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
This is great news.  If ImagePrint 5.0 is half as good as Andrew
claims with b&w, and works equal magic with color, Colorbyte will be
enjoying many sales indeed.
For now, I'll resist putting any time and money toward building
custom ICCs and see how ImagePrint alone fares.
Dan
--- In DigitalBlackandWhiteThePrint@y..., "Andrew Biggs"
> and the unlimited profiles rumor is definitely true.
> Apparently, they already have a very large number of
> desktop version will be $495. Currently the Epson 2200
> -Andy
I think we will be getting some pretty quick feedback from people.
However, Andrew is out of town for the next week, so maybe not so quick.
	Sent: Friday, September 06, 2002 3:00 PM
will be
	Dan
	> -Andy
ADVERTISEMENT
<http://rd.yahoo.com/M=212804.2303158.3720906.2225242/D=egroupweb/S=1705
019182:HM/A=810327/R=0/*http://geocities.yahoo.com/ps/info?.refer=blrecs
019182:HM/A=810327/R=1/*http://geocities.yahoo.com/ps/info?.refer=blrecs
at:
this same page.
subject header.
2002-09-07 by Bob Frost
Andy,
And the rest! Reading the 'small print' on their site, $495 dollars entitles
you to use the program on one printer and receive upgrades and support for
only 90 days. After that upgrades and support will cost you another $495 PER
YEAR, as will use on another printer.
Bob Frost.
ImagePrint support
2002-09-07 by ruhrfoto
--- In DigitalBlackandWhiteThePrint@y..., "Bob Frost"
<bobfrost@b...> wrote:
> Andy,
dollars entitles
and support for
another $495 PER
> Bob Frost.
Just for the records:
they have been supporting and updating/upgrading me now
since 5 months without charging anything.
And I´m not a ß-tester.
Bernd
