As I teach both the Zone System and Digital printing now, I've been
pondering this for a while...
>My initial questions/thoughts are:
>A How can I carry out Zone system calibration digitally? Or .
The traditional Zone System "tests" determine film speed (usually
Zone I density .1D over film base plus fog to ensure printable shadow
density) and developing time (to adjust film gamma to a given paper's
ISO range at a specific highlight value, usually Zone VIII or IX).
Neither are necessary for digital scanning/printing, but applying the
principles can simplify workflow and adjustments.
For example, using a film speed that places Zone I at .1D above film
base density allows setting the black point on the clear film and
avoids clipping shadow detail.
Zone VIII highlight negative densities are usually between 1.0D and
1.5D, depending on paper grade and type and enlarger (cold light
needs more). That is a fraction of the density range capability of
even flatbed scanners, of course.
While silver paper has a fixed ISO range, being able to select any
white point in digital would seem to negate any need to adjust film
gamma. Well, yes, in the same way auto focus eliminates the need to
focus. The trade-offs include a loss of predictability, control, and
subtle effects.
With many films, changes in development changes curve shape,
graininess, and local tonal separation as well as overall contrast.
These are all part of the "pre-visualization" which is the creative
(as opposed to problem-solving) side of the Zone System. "Fixing it
in Photoshop" is not unlike depending on dodging, burning, and
split-filter printing to remedy poor exposure/development decisions.
Why intentionally make image adjustment (darkroom or digital) more
difficult?
One way to bring more predictability to the negative scanning process
is to set the white point at a fixed value. You can do this by
including a Kodak 96 2.0 neutral density filter in the scan, and
setting the white value there rather than in the individual negative.
A 2.0D range is roughly equivalent to the ISO range of a grade 00
silver paper, so the image will look dark and flat . The 256 steps
will then be mapped over a density range which will not stress the
scanner, and you will have plenty of room to adjust the contrast by
moving the 90% point up in PS curves (detail above 90% will be
compressed much like a film shoulder when you do this).
Alternatively, scanning with an 21-step Stouffer wedge alongside the
negative allows setting the white point in predictable increments,
much like doing N+/- developing, or using contrast filters. This
particularly fun with 16 bit raw scans.
>B - Should I carry out all negative and proofing procedures
>normally in the "wet" darkroom and then scan the resulting
>negatives for digital output?
Yes, if you envision making conventional prints for any reason. But
if you only calibrate for digital, I'd concentrate on N and N- times
and techniques. Expose for the shadows and develop for the highlights
still applies. N+ times increase graininess and sacrifice shadow
detail in a trade off for contrast.
> Or . . .
>C - Do a classic "ring-a-round" for various lighting
>conditions
>and analyze the histograms for the best digital output?
>Option "C" sounds intriguing, has anybody tried this? ALL
>opinions on these or other options are most welcome.
Edward Steichen was famous for this approach: 2000 exposures of a
teacup and saucer, as I recall. In digital, if you set endpoints
within the image, the software will try to eliminate differences.
While this makes sense in the pre-press/transparency density range
compression application the scanner software was designed for, it
frustrates the control the Zone System was intended to provide.
Bruce
Bruce C. Kinch
Associate Professor of Photography
The Art Institute of Boston at Lesley University
