Any way to remove banding on Epson Stylus 740
2002-08-29 by heliar333
I have an Epson Color Stylus 740, which does a nice job, although it is definitely an older, slower model. I have tried to remove the subtle banding that only apparent in large areas of similar light tones - by using the Epson driver function that lets you clean the nozzles. When one try didn't work, I tried it a few times in successsion. The result was ink on the rollers. I also tried changing the setting that controls how tightly the paper is run through the rollers. That does not have a noticeable effect. I am using Epson Glossy Photo paper. For a printer of this type, are there any other options ? Are newer printers less susceptable to banding ? Any insights would be most welcome. - Ken Lee
