Re: [Digital BW] Re:EAM+Piezotones: Printer beware!
2002-09-08 by Martin Wesley
Sent: Sunday, September 08, 2002 1:00 PM
Subject: [Digital BW] Re:EAM+Piezotones: Printer beware!
> > We have long known that carbon pigment inks warm even in the absence of
> > light. It is probably an oxidation reaction and this is may be the
advantage
> > of the Epson encapsulated inks.
> Martin,
> I have just looked at an EAM and a German Etching print of the same image
> which were kept in the dark. The "browning" out did not happen. These were
> letter size proofs of work in progress, with similar "black" areas,
printed at the
> same time as the big prints. I believe the reaction of the black Piezotone
ink is
> related to exposure to light and possibly air. The dark-stored prints were
also
> kept in a plastic bag (the kind that comes with EAM).
Interesting information. The original Piezo/Sundance inks does warm even if
left in a box but is very paper dependent. We just don't know enough about
the chemistry of these inks to be able to know what is going on but light is
obviously a trigger. Didn't you stick a PT print in a window at one point or
am I thinking of someone else?
> I have a 2200 on order and am looking forward to using it with the
ImagePrint
> driver when released. Then I can compare the encapsulated inks directly
with
> the quads.
I definitely look forward to hearing your impressions.
> > Paul sent me some scans of wedges Robert printed with the PT-K replaced
> with
> > the FS-K which looked pretty good, although it is hard to tell from
scans of
> > wedges. I hope to hand load some cartridges next week and see how it
> looks.
> > I was willing to stay with the existing Sel-PT and take my chances
because I
> > like the look so much but this abrupt failure gives me second thoughts.
> According to Robert, FS-K works well with EAM and Hahnemuhle, but Museo
> likes the MIS-DD black. This as far as dmax goes - fades are another
story.
> Incidentally, I printed some grayscales using each individual ink/nozzle
to
> print the whole scale. I did this with WT-PT and the color of the black is
very
> startling next to the grays. Looks like a whole other animal. Who knows
what
> kind of thinking is behind using this same black for all flavors of PT.
Looks to
> me like they needed the money before they finished the R&D....
The PT-K is red-warm from my measurements and unfortunately that may be key
to the "look" of the Sel-PT ink set. I will be interested to see how the
overall hue changes with a different black. Were all of these prints from
the same batch of black?
> > BTW, what were the temperatures where the prints were stored while you
> were
> > gone? Robert and I have theorized that Paul's fader which has lower
light
> > levels than the commercial faders but much higher temperatures is
> revealing
> > flaws not seen in say RIT testing where there is strict temperature
control.
> This is a room that warms up in the late afternoon, as all Spanish-style
houses
> do in Southern Cal., but we enjoy relatively low humidity. In any case, I
don't
> think there were any particular extremes during July and August that would
> cause unusual degradation. This isn't an attic or a basement, just your
basic
> living room.
Well that doesn't sound like a torture test.
> So, as long as we keep our prints carefully sealed in bags in a dark
drawer,
> all is well with the PiezoTones!!
> But seriously, have you left any PT prints with lots of black, printed on
> Hahnemuhle papers out in the air and light (for longer that 2 months)?
Well my work prints tend to drift around the house a bit but they don't get
any direct sunlight and only minimal indirect. Tend to float to the bottom
of the pile and be covered. The finish prints go into plastic sleeves open
at both ends and are in stacks or in boxes. So far I have not noticed any
problems but I am rather nervous at this point. If the Sel-PT with the FS-K
looks good I will be playing it safe and going in that direction. Paul's
fade test still show the FS-K to be the best of the 3rd party inks in terms
of warm/fade.
Martin
2002-09-08 by antonisphoto
--- In DigitalBlackandWhiteThePrint@y..., "Martin Wesley"
Martin,
keep in mind that I am not complaining about "fade" or "warming" overall,
which we have learned to live with. It's this nasty separation of just the black
ink going brown and lighter than surrounding tones that makes the whole print
ready for the trash.
Admittedly, hanging uncoated, unframed prints is supposedly against archival
procedure and hence really meant as an "edurance test". But with the
Sundance inks, I have prints left exposed to the elements for over a year and
they have warmed and (I am sensing) faded a bit, but never separated into
this solarized look.  And it only took 2 months for it to happen with the PTs.
Yes I did and still do and took another look today: I don't see the same
bronzing out I saw in the big prints. The areas of black are small but don't
seem affected. This was a print from an 1160 made with beta carts of WT-PT
on EAM and exposed to similar light as the big prints - in fact for much longer.
They were printed using the piezo plug-in.
Could there be something else going on? The 7000 prints used sealed 7000
carts bought from inkjetmall. All of them exhibit the same bronzing out, there is
no difference from early to later prints. The printer was flushed using flush
carts also from IJM - everything was done by the book. Do we have a bad
batch theory here?
key
Yes.
> of warm/fade.
I think I will need to test that combo immediately and send the PT black carts
and bottles back to IJM for refund. Too bad; I had high hopes - despite the
early warnings from Paul - about the PTs.
Too good to be true, I guess.
Antonis
2002-09-08 by dgabbe2001
--- In DigitalBlackandWhiteThePrint@y..., "antonisphoto"
> Martin,
"warming" overall,
just the black
the whole print
I'm curious if any one has tried any of the UV sprays like
ImageShield or PrintGuard (or your favorite one) with the new
PiezoTone inks.  Unfortunately my SN-PT 1280 cart arrived w/the
blue meanies so I've been unable to start my "kitchen wall" tests.
During the Cone workshop I attended in Aug, Jon said the black
ink has an additional component in it which is not a dye, but may
behave like a dye.  He also said in post
http://groups.yahoo.com/group/piezography3000/message/1941
0 (at the very end), they would fix real problems.  So I hope
people are sending samples to him!
From my perspective, quad tone printing is still in it's infancy.  I've
been with the Piezography system for 2yrs and it just seems to
take some time to understand what happens.  For example, I ran
Concord Rag tests for a year.  Even w/a UV spray, I won't dream
of selling a print.  Another example, my William Turner 190 test
has been running for 10 months.  Even w/ImageShield, the
fading is strong enough to really bother me.  However, the same
print in the living room, 2ply mat on back, 4ply mat on front,
w/glass and QuickClips has much much better density.  The
living room receives much less light.  In fact, C prints will fade in
the kitchen after a year as a point of reference.
The original Piezography inks damaged 3 different printers of
mine.  For me, there is no going back to them.  The new
selenium inks look great so I'm waiting to see if the black
problems can be resolved by modifying the ink.
Dave G.
2002-09-09 by Robert Morrison
Martin, ask Paul to scan the wedges...he has them now...they didn't look too
bad.
Robert
2002-09-09 by Martin Wesley
Sent: Sunday, September 08, 2002 3:59 PM
> Martin,
black
print
archival
and
PTs.
Antonis,
I think we have had similar experiences. I have original Piezo prints that
are 18 months old that look fine. There are a couple on papers like H.
Torchon that have warmed to the point of orange. All of these were in low
light situations. Overall if there was any fade it seemed consistent across
the tonal range so that the it is not apparent. The PiezoTones have the
highest marks to date for the gray inks in the mid tones of any of the
carbon pigment ink sets. So they are not to be forgotten but rather fixed.
don't
longer.
Well this should be driver independent. Same paper? Same paper lot? Is there
any chance that the 7000 laid down so much ink down there was excess sitting
on the surface?
there is
flush
> batch theory here?
Well the "bad batch" theory" is a valid one and we have seen batch problems
before with all the ink manufacturers. What concerns me is this failure is
exactly along the lines suggested by Paul's fade testing. The black warms
and fades much faster than the grays resulting in an unpleasant color
crossover and tonal posterization in the deep shadow tones around 80-85%.
Although the effect did not look as unpleasant in the scans of the WN-PT as
it did with the Sel-PT.
(snip)
terms
> > of warm/fade.
carts
Robert has already tried this and sent wedges to Paul on both EAM and Photo
Rag. These look pretty comparable. I have posted Paul's scan of the wedges
in folder:
Files > Ink Sets > PiezoTones
I have just finished loading some Sel-PT grays and the MIS-FSN into
cartridges. After I have printed some wedges and test prints I will post my
impressions and some spectrophotometer readings.
Well I still like the hue of the Sel-PT over anything else and the midtone
warm/fade is still tops, so at least that part is right. The black issue
hopefully will not be too hard to fix. I heard a rumor to the effect that
ConeTech was considering offering an alternative black without the "dye
stuff". If there is any truth to this, then the fix may be at hand already.
Martin
2002-09-09 by Paul Roark
Martin wrote:
>The original Piezo/Sundance inks warm even if
Antonis wrote:
>... I am not complaining about "fade" or "warming" overall,
>which we have learned to live with. ...
We should not have to live with warming.  I think is it just a sign of inks
that have not really made the grade.
Some fading seems inevitable at this point.  However, the best of the
inksets hold the warming to a minimum.  I'm sure the inksets will slowly get
so good that the fading issue will ultimately be so trivial that it is just
ignored.  However, for today, avoiding sun and glass -- better yet glass or
acrylic with UV absorption -- is the best bet.
Frankly, I use cheap acrylic and have MIS VM-S and FS-N quads on my
refrigerator door.  The main threat I see is physical damage, and one coat
(three passes) of a protective spray takes care of that.  (It does not
retard fading or warming, or otherwise affect the look of the image.)  The
photos on my refrigerator look great.
One other point regarding the PT-K and it's warming/fading -- the driver may
make a difference.  On the one hand, one advantage of a RIP is that one can
hold the black ink down to the darkest levels, thus hiding warming in the
depth of the shadows.  On the other hand, if the transition between the inks
is too abrupt -- not feathered appropriately -- the faster fade of the black
ink will cause a more sever cross-over and possibly posterization.  This
would be especially true if the transition took place too soon -- in too
light a tone.  So, how one manages the dark gray (mostly cyan-position ink)
to black transition is likely to make a difference with respect to how much
the warming/fading of the PT-K affects the image.
http://www.PaulRoark.com
