Tablets was Burning Skies (feathering)
2002-09-10 by Martin Wesley
Carolyn, Thanks for the neat techniques! This does bring up the subject of using tablets with PS for photo editing. Like most I use a mouse which is often a real pain when trying to refine masks. I gather that Wacom is still "the brand" in this technology. What do you recommend in terms of minimum useful size and any particular model? Martin Wesley http://www.borderless-photos.de/guests.html ----- Original Message ----- From: "Carolyn Frayn" <carolynfrayn@...> To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Monday, September 09, 2002 4:57 PM Subject: Re: [Digital BW] Burning Skies (feathering) > Rick wrote: > >> This works fine most of the time but whenever I have open, > >> evenly illuminated areas, i.e. blank sky, calm water, I get a slight > >> to horrendous posterization. It's very subtle on the monitor but > > Martin wrote: > > This will give you a gradient spread over a much larger area of the image. > > How smooth for your purposes I am not sure but worth a try. (Did I get that > > right Carolyn?) > > I don't remember.. <gg>. To make smooth transitions now, I do what you're > suggesting, large - large brushes, they don't give that banding that > feathering/blurring marque selections are known for. I would have moved to > PS7 for the brush sizes alone. > > I usually create a curve adjustment layer, don't do any curve moves (it is > simply acting as a dup image layer), attach a layer mask, choose multiply > blend mode and then with one large or various sized brushes (or wacomb pen > with variable pressures) paint the the mask to effect the areas of the image > you'd like. This gives me the smoothest transition to date. Then adjust your > opacity to suit your tastes. > > Try two ways, keeping the large brush mostly off canvas, using only the edge > for the feather. Switch back to black, and paint inner areas where you want > to erase the effect.. you can achieve a very good smooth mask. > > Or, with the layer mask filled with white, select black, and paint with the > largest brush you can inside the image, with a steady hand follow your edges > (or go off the canvas altogether if you're just after the corners), the edge > of the brush creates a good rounded smooth transition at the corners either
> way, no banding. > > You can also give the curves a tweak in multiply mode for different > strengths and effects. > > sorry Rick, not much help here for earlier PS's. > Carolyn >
