PS Quadtones vs. a dedicated system
2002-09-12 by voranado
I have been lurking on the list for a while and have a relatively basic question that I have not seen discussed. (If it has been well covered in the past, I would appreciate it if someone would let me know off-line at kobrins@....) I have been scanning negatives (typically Ilford fp4 or 5) into PS for a few years and printing PS tri- or quad tones, most recently on an Epson 1200. While I am reasonably satisfied with the results, I am about to upgrade the printer to a 1280. Most of the discussion of dedicated quadtone inks such as MIS or Piezio on the list seems to revolve around longevity. I am a rank amateur and the print's life expectancy, while not irrelevant, is not my primary concern at this point. Now the question: is there a significant difference in the "quality" of the output between a well produced PS quadtone using the standard Epson inks (1280) and one of the systems using dedicated quadtone inks? In short, is it worth dedicating the 1200 to B&W and installing either MIS or Pieziographic inks? I certainly have a long way to go in improving my PS workflow and a lot of experimenting to do with papers before I am even near getting the best possible output from Epson inks. On the other hand, as I will have a spare printer after the upgrade, this is an opportunity to move to a dedicated system. (I have also thought about a 2200, but given the 1280 rebate, that is a lot more money at this point.) I realize this is a very subjective issue, but any help would be appreciated. Again, I apologize if this has been covered previously, and if so just aim me in the right direction. Steve kobrins@...
