Re: [Digital BW] Balancing Adobe Gamma & a 21 steptablet
2002-09-13 by CDTobie@aol.com
In a message dated 9/12/02 10:18:38 PM, frank@... writes:
>Or, using the wizard, I set my contrast and then brightness until the
>middle square is "as dark as possible but not black" - still
>distinguishable from its surrounding.
>All as per instruction.
>Now if I view (under the same light) a 21 step tablet the 95/100%
>almost meld into one another Pretty close to being indistinguishable
>which is not right.
Then you need to go back and adjust the settings for that black-on-black
square...
C. David Tobie
Design Cooperative
CDTobie@...
Re: Balancing Adobe Gamma & a 21 steptablet
2002-09-13 by frankg_photo
indistinguishable
> >which is not right.
black
> square...
> C. David Tobie
Then except to get me into the ballpark, there's no value to the
Adobe gamma setting - I may as well only use the 21 step tablet to
set the brightness until I distinguish all the steps ?
