Re: [Digital BW] 2200/colorbyte B&W with spot color?
2002-09-13 by CDTobie@aol.com
In a message dated 9/13/02 11:56:57 AM, jimhayes@... writes: > Like doing a field of sunflowers in B&W with just one petal yellow... > > Or maybe just adding a heavy bluish, reddish, etc tone like the > darkroom Berg toners to the overall print. > > Or both? Can the $500 colorbyte package accomodate this? Either? > The question is not whether the RIP can do this, its what inkset you would need to accomplish it. The ColorByte RIP is designed to be used with grayscale inks for grayscale work, or with color inks for color work. If you wish to do both (as your examples describe), then you will not get any of the special advantages of the grayscale system, and will be dependent on the color profiles to produce your grays with the color inks. C. David Tobie Design Cooperative CDTobie@... [Non-text portions of this message have been removed]
