Re: [Digital BW] Cheap Scanner ??
2002-09-15 by Ken Lee
Have you tried adjusting the scanner settings, or are you just using the
default settings ?
Sent: Sunday, September 15, 2002 6:44 AM
Subject: [Digital BW] Cheap Scanner ??
> Well, now that I finally have a good BW printer ( Epson 2000P + MIS FSe ),
I set up this Microtek X12USL scanner ($270) and 5x7" transparancy adapter
lid ($80).
> I have some old glass 4x5 negatives from my grandfather that I wish to
scan and print, and I thought this scanner would work fine : Wrong !
> Although it is rated for 42 bit color and 2400x1200 resolution, the
dynamic range is just miserable. I cannot resolve anything in the darker
negative areas - they just show as white. I improved it a bit by scanning as
a Positive and then swapping afterwards ( in Picture Windows 16 bit mode ),
but in examining the negatives with a magnifier, I am loosing a great amount
of detail. No afterscan correction curves work properly - the data is lost:
the subtile grey shading in these deeper areas is not captured.
> 1) any tricks for wide white to black ratio negatives ?
> 2) what is an 'inexpensive' scanner capable of properly acquiring the
information from these, somewhat grainy and imperfect, but still interesting
circa 1900 negatives ???
> Thanks,
> Alex
>       Yahoo! Groups Sponsor
>             ADVERTISEMENT
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and
page.
them short.
&amp;amp;quot;flames.&amp;amp;quot;
resources on the homepage.
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
2002-09-15 by Martin Wesley
Alex,
I don't think this scanner is going to live up to your expectations. The
actual optical resolution is probably no more than 1200 dpi and I have to be
skeptical about the optics and electronics on something this low end. I
would recommend that you check out the Epson 2450 and 1680 scanners, $399
and $1,149. The best for the glass negs would probably be one of the high
end Scitex scanners but I assume you don't want to part with several
thousand dollars. As someone suggested, you might want to contact a service
bureau with a high end flat bed and have some things scanned so that you can
see the difference.
The scanner is probably more important or as important to getting a good
print as the printer.
Martin Wesley
http://www.borderless-photos.de/guests.html
Sent: Sunday, September 15, 2002 3:44 AM
lid ($80).
> Thanks,
> Alex
page.
them short.
Re: Cheap Scanner ??
2002-09-15 by B. Alex Pettit Jr.
Hello Martin,
I will take your advice and have a few commercially scanned to see what quality I can obtain...
As I recall, there are hundreds of these old 4x5s. I just need to get my Father to send them all to me then I can ascertain the value in purchasing a better scanner.
Do you think the Epson 1680 would be an 'effective' scanner for this purpose - considering the age, film grain and general degredation of old glass negs ?
Thanks ( again and again ),
Alex
I
> see the difference.
> Martin Wesley
> From: "B. Alex Pettit Jr." <a_pettit_jr@y...>
> To: <DigitalBlackandWhiteThePrint@y...>
> lid ($80).
> > Thanks,
> > Alex
> page.
> them short.
