UltraChrome Fade test
2002-09-20 by Paul Roark
The fade test of the UltraChrome "B&W" test strip in my fluorescent light
fader has reached 300 hours.  It was tested against the MIS Archival
pigments (with the tougher yellow, like Gen4, and the VM/FS black -- what I
use for color) the PiezoTone Selenium inks, all on Archival/Enhanced Matte.
The important results are, first, that the UltraChrome matte black at the
100% patch maintained its 1.73 density -- no measurable fade, outstanding.
The VM/FS black lost 0.02 units, dropping from 1.63 to 1.61.  The PT-K
dropped from 1.71 to 1.62.  (We must see if the UltraChrome matte black
works in standard old Epson printers.)
Second, the magenta pigment appears to be the weak link in both the MIS
pigments and the UltraChromes.  However, whereas the UltraChrome magenta
dropped only 0.01 unit, the MIS magenta dropped 0.04 units.
So, while the UltraChrome shift was not visible yet, the MIS test strip is
visibly shifted.
Both the UltraChrome 50% patch and the PiezoTone 50% patch dropped only 0.01
units in visual density.  An excellent performance.  The PT-S warmed 0.01
unit.  The MIS 50% patch faded 0.03 units.
Visually, the only changes are the MIS Archival inks shifting, the paper
yellowing, and the PT-K fading and warming (which is not news any more).
So, the star is the UltraChrome matte black, and the UltraChrome and
PiezoTone midtones are both excellent and about equal.
I would guess -- speculate based on what I've seen in other testing -- that
the UltraChrome will continue to turn slightly green, whereas the quad
midtone will probably tend to stabilize.  However, it would take more
testing, and that may not happen for a while.
http://www.PaulRoark.com
Re: [Digital BW] UltraChrome Fade test
2002-09-20 by Robert Morrison
Thanks Paul.  I have a 7600 cart of matte black that I am going to use to
fill a 7000 and 1280 black cart (as soon as they arrive from MIS) and then
run them with the Selenium Piezotones in both printers using the piezo,
imageprint and epson drivers.  The problem so far with the Ultrachromes is
that it seems that they only give a good black on EAM...performance is worse
(at least using the epson driver) with any other matte paper.  This is
probably the result, once again, of not having the proper paper settings in
the epson driver.  Perhaps we will be able to get around it with imageprint.
Robert
> visibly shifted.
> Paul
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and other
> resources as they are often being updated. The page is at:
> page.
> them short.
> &amp;amp;quot;flames.&amp;amp;quot;
> resources on the homepage.
2002-09-20 by Jerry Olson
Paul, would the ultrachrome matte black be compatible with either
generations or MIS inks though?
Jerry
Shouldn't be a problem...just don't mix the inks in a cart of bottle. I
don't think that head capping cross contamination is a serious threat for
any of these systems.  I've recently used three different blacks in tests
and haven't had any problem.  When you get into problems is when you
actually mix inks in the lines that supply the head. As mentioned
previously, I will be using the ultrachrome black with the piezotones in a
test soon.
Robert
> Jerry
> page.
> them short.
2002-09-20 by Antonis Ricos
Paul,
since I did this test:  yes! And PR is the only one (so far)  that doesn't sheen in
the blacks.
Go figure... ! <g>
Antonis
--- In DigitalBlackandWhiteThePrint@y..., "Paul Roark" <paul.roark@v...>
wrote:
> Robert,
> Is the UltraChrome matte black weaker on PhotoRag than EAM?  That
would be a
> first.
> Paul
RE: [Digital BW] UltraChrome Fade test
Robert,
Is the UltraChrome matte black weaker on PhotoRag than EAM?  That would be a
first.
_____________________________
  Sent: Thursday, September 19, 2002 6:11 PM
  Subject: Re: [Digital BW] UltraChrome Fade test
worse
in
imageprint.
  Robert
light
what I
Matte.
outstanding.
is
  > visibly shifted.
0.01
0.01
that
  > Paul
other
same
  > page.
keep
  > them short.
header.
        Yahoo! Groups Sponsor
              ADVERTISEMENT
page.
them short.
On 9/19/02 9:56 PM, "Paul Roark" <paul.roark@...> wrote:
> Robert,
> first.
> Paul
Not unheard of.  EAM was also better for GenElite black.  MIS DD was close
to equal on the two papers.  Hahnemuhle really likes dyes (probably because
of the PVA resin in the coating)...thus Gen 4 and Piezotone Black do really,
really well on Hahnemuhle.  MIS FS only does slightly better.
Robert
2002-09-20 by Martin Wesley
Antonis,
Is the UC black weaker than FS black on Photo Rag and the other H. papers?
Martin Wesley
http://www.borderless-photos.de/guests.html
Sent: Thursday, September 19, 2002 9:53 PM
> Paul,
sheen in
> the blacks.
> Go figure... ! <g>
> Antonis
> wrote:
> > Robert,
> would be a
> > first.
> > Paul
page.
them short.
2002-09-20 by Ernst Dinkla
Thank you for all the work done, nice to see the wished results.
Quads and hexatones for an Epson 3000 and 9000 with an Ultrachrome black and
Ultrachrome 50% to begin with and a fluid to mix the other tones then.
AFAIK, the Black is a bit sepia and the 50% has a yellow cast, are they too
much different in colour ?
Mediastreet's Jrano is worth a try for mixing or do you have another advice
Ernst
