Horizontal lines
Horizontal lines
2002-09-20 by akivisuals
Hello again.  I've got an issue with my printers (1520 using Piezo
original inks and 1160 using CIS with MIS FS-N inks) both
printing some horizontal lines.  They're spaced around a half
millimeter apart.  I have a jpeg of the problem that I scanned but
don't know how to post it to this site for people to look at to help
me diagnose my problem.  I have the same problems on my
1160, which I just had the printhead replaced on by an
authorized Epson service center.  The files are being output at
300dpi using the Piezo driver.  Any ideas would be greatly
appreciated.  Thanks!
Andy
Oh, I can email the pics to those interested in looking.
Re: Horizontal lines
2002-09-21 by Peter VG
Hi Andy,
I occassionally see the same banding with my epson 1200 using MIS VM
inks. What i found was that checking the heads using the epson
software does not always work, eg. nozzel check looks good but
actually you have a clogged head.  I now print part of the purge
files avaliable on the MIS site to see if my heads are clean.  I use
about 1/4 of the purge file and rotate it 90 degrees.  If one nozzle
is clogged you will see it and which color it is happening with.
Then you just running cleaning cycles until it goes away.  I find
that i have to do this every few days if i am doing a lot of
printing.  When you get a perfectly smooth purge print then you know
your ready to stick in a piece of expensive paper.
Peter
--- In DigitalBlackandWhiteThePrint@y..., "akivisuals"
help
> Andy
2002-09-21 by akivisuals
Thanks Peter.  I usually do a nozzle check before printing as
well.  They normally print fine so I just assume that the nozzles
are fine.  I'll try printing the purge file though.  Funny thing is that
the print heads are brand new.  I just had them replaced.
Hmmm.....
Andy
--- In DigitalBlackandWhiteThePrint@y..., "Peter VG" <pvg@y...>
wrote:
> Hi Andy,
using MIS VM
epson
but
use
nozzle
know
> Peter
Piezo
but
> help
at
> > Andy
