2200 print speed
2002-09-21 by Antonis Ricos
What a difference a CPU makes!.... I usually assign an older computer as print server, and in the case of the 2200 I had it connected to a Mac with dual 601 chips - a perfectly capable machine in other ways, just slow. It used to print from the 1160 very quickly, so I never thought the CPU speed mattered. When I hooked up the 2200, I resigned myself to those usual 15-20 minute print times I had seen with the 1280, regardless of using firewire or USB. Today I hooked the printer up to a G4/800 (firewire) and saw the real speed: A 37 MB RGB file going to a letter size print at 1440, High Speed = OFF, took a mere 7 minutes from clicking "Print" to finish. That's why this one has the firewire, I guess. Impressive! Antonis
