MIS Variable Mix Quadtones - Hex printer
2002-09-26 by william oldacre
Hi all,
I've looked in the forum briefly and I'm not finding anything that
indicates a method for writing curves. Could anybody point me in the right
direction or brief me on the method for writing curves.
Do you need to isolate each of the 6 inks and figure out the crossover
points or what exactly?
Thanks
William
Best regards
William Oldacre
me@...
698 Queen Street East
Toronto, Ontario    M4M 1G9
Canada
www.wfomixedmedia.com/portfolio
studio    (416) 405-9929
fax        (416) 778-6200
Re: MIS Variable Mix Quadtones - Hex printer
2002-09-26 by Jeff Randall
William:
The best place to start is to open one of Paul Roark's RGB
partitioned curves for the hextone VM inkset and your printer (see
the Quad workflow pages at MIS, www.inksupply.com for curves and
workflows) .  Check out the individual R, G, and B curves with your
photoeditor's curves tool.  The R curve controls the C position inks,
G the M position inks and B the Y position ink.  Tweak the curves to
get a smooth stepwedge and ramp on your printer.  You can do this
visually, scanning the stepwedge portion of the test print with a
flatbed scanner and checking the positions of the peaks with the
histogram feature of your photoeditor, or directly measuring each
step patch with a densitometer, colorimeter, or spectophotometer.
Good Luck.
Jeff Randall
--- In DigitalBlackandWhiteThePrint@y..., william oldacre <me@w...>
wrote:
> Hi all,
the right
crossover
> Thanks
> William
> Best regards
> William Oldacre
> me@w...
> Canada
> fax        (416) 778-6200
