ImagePrint 5.0 - Judge for yourself.
2002-09-27 by bart7172001
After all this hype about IP5 5.0 (a.k.a Spectrum Pro 5.0) I decided to check out the software for myself and compare the results from both engines (drivers). I prepared couple crops-scans with comparisons of both printouts using Epson driver and IP5. See the following link: http://www.pbase.com/bartek/gallery/imageprint_50 Here is what I did: I used the well known PDI-Target.jpg image. I used PS7 with Epson supplied custom printer profile and in the driver I used NCC (No Color Correction) and PGPP (Premium Glossy Photo Paper), 2880 dpi, and hi-speed off. I used the same picture with IP5, utilizing their custom printer profile, the same paper, and 2880 dpi. (Hi-speed off) Results: Color - printout with IP5 has much more accurate colors, shadow detail is superb. Their color profiles are very accurate, way better then Epson's. I am not sure about the gamma the difference to Epson is huge, Epson prints are way darker in comparison. Is it possible that Epson is that much off? Sharpness to a naked eye both images look the same, however under magnifying glass (and in the shown scans) Epson printout is sharper. Grain and visible dots again, to a naked eye both images look the same, nevertheless under magnifying glass (and in the shown scans) Epson print is butter smooth with almost zero grain. I can not say that about IP5, as you can see yourself the grain is clearly visible and the dithering is worst than Epson's. B&W IP5 is using custom gray profiles for B&W prints. When you print with IP5 you have to specify what ink set you want to use, in case of B&W I had to specify "Gray Pigment". The IP5 approach to B&W is very clever; they decided not to use all 7 inks for B&W thus allowing them to achieve very neutral results by utilizing mainly Black and Light Black inks for B&W. Indeed the B&W prints are 100% neutral as Andrew Rodney called it `dead nuts neutral'. The software itself is not very user friendly, interface looks more like an unfinished product - rough and cryptic. I am myself a programmer, so to me it looks like all my programs when they are in the Alpha stage of development. I am now debating if this software is worth $500 basically just for B&W, well maybe for the excellent profiles as well. So where is the butter smooth, superior to Epson dithering IP5 is advertising? Andrew (Rodney) was this not your comment at one point? I would like to be wrong I had high hopes for this software, I was anticipating software which would give me an excuse to spend $500, where the output will be truly superior. Please prove me wrong, show me what I am doing something wrong. Did I get a wrong version? Did anybody see better output from IP5 than that? I am not saying that IP5 is bad, it is not. The output it produces is comparable to Epson driver, but definitely not better. It has better shadow (because of lower gamma?), better color (because of better printer profiles?) and unquestionably better B&W. BTW there was some discussion about custom profiles from ColorByte and that the company would supply them for free on request for registered users; does anybody know if this is true? PS. - The white lines you see in my scans of IP5 are watermarks the IP5 demo version applies. - Also, I have more scans if anybody needs more proof.
