Re: [Digital BW] New EAM
2002-09-29 by Paul Roark
Shilesh,
Your wrote:
>I posted a message about a month ago on new EAM being warmer.  The
>paper I bought was also from Atlex, 8.5 x 11, Lot No. 02CC2004M. I
>found the same Lot No. at the local CompUSA, equally warm. And yes,
>it has weaker blacks. ...
>this is really bad because EAM is THE inexpensive steady
>war-horse ...
Yes, I recalled your post when I ordered my new EAM from atlex.com.  I guess
it was wishful thinking that Epson had taken care of the problem.  I wonder
how long this lot number is going to be out there.
The letter-size EAM I received is lot # 02CC2004M -- the same are yours.
The paper white on it reads: c=0.05, m=0.05, y=0.04, visual=0.05.  The black
is between 1.60 and 1.61.
Several older batches of EAM have white paper readings of c=0.04, m=0.04,
y=0.03, visual=0.04.  So, the new doesn't actually read yellow; it's just
not as bright.  It does have a more yellow look, however.
The blacks on my old EAM samples are not consistent.  On my 1160 I usually
assumed I'd see between 1.64 and 1.65.  A January 2002 test strip that has
been in dark storage (but close to acid paper) reads 1.65.  A test strip I
printed with the 3000 yesterday on the January paper has a black density of
1.66.  I usually do expect slightly darker blacks with the 3000.  The new
EAM, thus, is about 0.05 to 0.06 units weaker in the blacks than was the
January batch.
On the other hand, the batch of EAM I just used up routinely hit 1.68 with
the 3000.
I cut a small piece of EEM off a new roll I purchased.  I don't know the lot
number.  The roll has the expected white paper reading of c=0.04, m=0.04,
y=0.03, visual=0.04.  However, it's blacks only hit 1.64 with the 3000.
So, the paper is just inconsistent.  The new batch that only hits 1.60 with
the 3000, however, is so weak I'm going to complain and see if there is a
possible swap I can make for a different batch number.  I suppose I'll start
with the Epson Connection # (800)463-7766.  If anyone has a better number,
let us know. If that is the only batch, I suppose I'll keep it -- at least
until there is a better lot number out there.
http://www.PaulRoark.com
2002-09-30 by Dan Honemann
--- In DigitalBlackandWhiteThePrint@y..., "Paul Roark"
Makes me wonder if the "new" EAM is actually _old_ EAM, since this
paper is known to yellow with age.
Dan
2002-09-30 by Jeff Randall
Paul:
I get EAM densities of c=0.05, m=0.05, y=0.03, visual=0.05 if I back
the sheet with a dark sheet, and c=0.04, m=0.03, y=0.01, visual=0.03
if I back it with a white sheet.  How do you take your density
measurments?
Jeff Randall
Preston, WA
I --- In DigitalBlackandWhiteThePrint@y..., "Paul Roark"
> Shilesh,
> >war-horse ...
atlex.com.  I guess
I wonder
yours.
The black
m=0.04,
it's just
usually
that has
strip I
density of
The new
was the
> January batch.
1.68 with
> the 3000.
know the lot
m=0.04,
3000.
1.60 with
there is a
I'll start
number,
at least
> Paul
RE: [Digital BW] New EAM
2002-09-30 by Paul Roark
Dan,
The only yellowing I've seen with EAM is the same I see with all papers with
optical brighteners in them -- they yellow with strong light exposure.  Once
the OB's have burned out, the paper is slightly yellower, but then it does
not further yellow -- until many years later when the acid may be a problem.
My dark-storage EAM prints are just as bright as the day they were printed.
_________________________________________
  Sent: Sunday, September 29, 2002 5:53 PM
  Subject: Re: [Digital BW] New EAM
  Dan
Jeff,
I read densities on a pile of white paper.  I suspect the differences we see
in our readings just reflect the inaccuracies of the machines.  As such, I
suspect only relative densities with the same instrument are accurate enough
to measure the differences we are seeing in the papers.
I asked an X-Rite rep about getting more accuracy -- including more
significant places.  It can be done, but we're looking at many thousands of
dollars.  So, I decided I could live with the limited accuracy.  It at least
beats the scanners I was using.
  Sent: Sunday, September 29, 2002 6:09 PM
  Paul:
  measurments?
  Jeff Randall
  Preston, WA
  > Shilesh,
  > >war-horse ...
  atlex.com.  I guess
  I wonder
  yours.
  The black
  m=0.04,
  it's just
  usually
  that has
  strip I
  density of
  The new
  was the
  > January batch.
  1.68 with
  > the 3000.
  know the lot
  m=0.04,
  3000.
  1.60 with
  there is a
  I'll start
  number,
  at least
  > Paul
        Yahoo! Groups Sponsor
              ADVERTISEMENT
page.
them short.
  - Good manners are required at all time. No personal attacks or
&amp;amp;quot;flames.&amp;amp;quot;
resources on the homepage.
Paul:
The backing *does* make a significant difference.  I just wanted to
eliminate one potential variable by comparing your apples to my
apples.  I think the majority of the difference between my white
backing readings and yours is more likely due to the paper lot (I was
reading off some just opened but older EAM, Lot # 01KK1026M). Of
course, Swatchbook instrument variability also contributes some to
the differences.
Jeff Randall
> Jeff,
differences we see
such, I
accurate enough
thousands of
at least
> Paul
>   -----Original Message-----
>   From: Jeff Randall [mailto:jrandall@c...]
>   To: DigitalBlackandWhiteThePrint@y...
>   Paul:
back
visual=0.03
>   measurments?
>   Jeff Randall
>   Preston, WA
>   > Shilesh,
The
02CC2004M. I
yes,
>   > >war-horse ...
>   atlex.com.  I guess
problem.
>   I wonder
are
>   yours.
visual=0.05.
>   The black
c=0.04,
>   m=0.04,
>   it's just
1160 I
>   usually
strip
>   that has
test
>   strip I
>   density of
>   The new
>   was the
>   > January batch.
>   1.68 with
>   > the 3000.
>   know the lot
c=0.04,
>   m=0.04,
>   3000.
hits
>   1.60 with
>   there is a
suppose
>   I'll start
better
>   number,
>   at least
>   > Paul
>               ADVERTISEMENT
Polls and
wish to
this same
> page.
messages to keep
> them short.
header.
various
Service.
2002-09-30 by Martin Wesley
Sent: Sunday, September 29, 2002 7:54 PM
Subject: RE: [Digital BW] New EAM
> Jeff,
see
enough
Paul,
This is interesting and may explain some of the differences we have seen
between your X-Rite Digital Swatchbook and my Spectrocam. The Spectrocam
came with a ~9x12 black plastic plate and the recommendation to place all
samples on the plastic with nothing else underneath the sample being read.
It does make a small difference too. If I place a single sheet on the plate
my EAM reads C=0.06, M=0.06, Y=0.00, V=0.06. If I stack sheets up I get
C=0.05, M=0.04, Y=0.01, V=0.05. In either case this is still representative
of the faint blue/blue-cyan tint I usually associate with EAM. The batch I
have is a couple of months old.
Martin
Martin,
It sure looks like your graph of my test data.
Note also the name of the new ink.  Then note my message in the B&W Print
forum:
_______________
      Message 17804 of 21045  |  Previous | Next  [ Up Thread ]  Message
Index             Msg #
      Date:  Mon Aug 5, 2002  7:43 pm
      Subject:  Re: [Digital BW] PiezoTone-PhotoRag 306 Hr. Fade test
      Richard,
      Sorry for the delayed response, but I've been out of town.
      You wrote:
      >Saturday, July 27, 2002, 8:50:38 AM, Paul Roark wrote:
      >PR> The super inkset, in my view, would be the PT midtones with the
MIS FS
      >PR> black.
      >From reading your charts it seems the MIS FS-N black has less warming
      >and fading than the MIS FS black so why not the PT midtones and the
      >MIS FS-N black? Or are the MIS FN black and MIS FS-N blacks the same
      >(as I think perhaps I had heard here before?)?
      The FS-N, FS, and VM blacks are all the same. If you compare one test
set
      with another, there may be differences in results. The paper makes a
big
      difference. Also, however, there may be minor differences from one
test
      session to another.
      >Also, if one sets up a CFS with the PT midtones and the MIS FS (or
      >FS-N) black would there need to be any adjustments in the drives and
      >curves used? i.e. if I currently use MIS-FS inks with the Piezo
driver
      >(and sometimes with Epson driver/Randall curves) will I also be able
      >to use the same but with the PT midtones inks installed instead of
      >MIS-FS midtones?
      I have not directly tried the PT inks, but my impression is that they
may
      have different densities than the original PiezoBW inks. At some point
I
      will probably buy some PT-Selenium cyan and see what it's density is.
If,
      as one test strip I've received suggests, it is denser than the
original
      PiezoBW cyan, I may experiment with diluting it to make it compatible
with
      the FS and original PiezoBW blacks.
      Frankly, I think Cone Editions ought to market a PiezoTone "Museum"
series
      that uses the original PiezoBW black (which I believe is essentially,
if not
      exactly, the same as MIS FS/VM black) and the original densities
(assuming
      the new ones are slightly different -- which is uncertain to me).
________________
  Sent: Sunday, September 29, 2002 8:28 PM
  > Jeff,
  see
I
  enough
  Paul,
plate
representative
  Martin
page.
them short.
2002-09-30 by Moreno Polloni
with
Once
problem.
printed.
The yellowing of EAM doesn't bother me in the least. In fact, it's hardly
noticeable compared to the yellowing of fibre-based silver paper that's been
around for a few years.
2002-09-30 by Jerry Olson
Perhaps we had all better start looking for an EAM Replacement just in case.
Anybody know of a paper that has a black at least as good as the older
EAM, and is a bit whiter?  Photo Matte easily is whiter, but the blacks
aren't as good. Same with
Eclipse Satine, better whites, but not blacks. The price will be a
little higher, I'm sure, but I'd not want any paper that costs as much
as  photo rag or any of the hahnemuhle papers.
I seem to recall CD Tobie recommending a Dotworks paper a long time ago;
has anybody tried this paper?
Is there any paper at all from Red River paper that is EAM comparable? I
tried their
sample pack once, and never found any of them to have a rich black.
How about Mitsubishi, or Weber Valentine?
Jerry
2002-09-30 by Linda Jacobs
Jerry, I do know that Redriver has introduced lots of new or improved
papers over the last 6 months or so. You can probably ask them via
email which ones might be closest to EAM and get the appropriate
sample pack.
I plan to stop by their place in the next couple of weeks and see what
they have and pick up some sample packs. Their offiice/warehouse just
happens to be fairly close to me.
LJ
Sent: Monday, September 30, 2002 10:59 AM
in case.
comparable? I
> tried their
> Jerry
2002-09-30 by Thom McGraw
Is the yellow appearance of this new batch quite
obvious?  I ask because I received a box of letter
size from Atlex today, but with a different batch
number (02DE2001M).  I compared it to my old batch (it
is so old, it doesn't have the epson watermark on the
back) and it does appear to be warmer, but not by
much.  However, from visual inspection of a printed
image, the blacks do seem a bit weak, almost in line
with eclipse black.  But, since I don't have hardware
to measure the actual difference, it could be my
imagination.  If I hadn't just read about the
different batches, I might not have noticed.
Thom
> the same are yours.
> however.
> blacks than was the
> January batch.
> the 3000.
> 1.64 with the 3000.
> Paul
> Bookmarks, Polls and other resources as they are
> digest, or you wish to unsubscribe, please edit your
> Membership preferences by visiting this same page.
> one.
> earlier messages to keep them short.
> attacks or
> archives and the various resources on the homepage.
2002-10-01 by Bill Agee
It was called Nature Jet...very reasonably priced rag type paper and
did a beautiful job with Epson dye inks for 1270 / 80, but bronzed a
bit with the MIS ARCH PIGMENTS.  Went away when sprayed, but that is
somewhat of a pain.
Bill
bill agee studio
capistrano beach, ca / laguna beach, ca
http://www.redsilver.com
small-sheet alternatives to 8.5 x 11 "new EAM"
2002-10-04 by Sam A. McCandless
Phil Morse posted that the 13 x 19 EAM/EM sheets he recently got were
not less white/more yellow.
Has everyone else who ordered 13 x 19 EAM/EEM recently been as lucky
as Phil? I guess we could cut it down to size.
Are there other sizes, hopefully A4, of EAM/EEM which are not less
white/more yellow?
Thanks.
Sam McCandless                samcc@...
holiday-card stock & envelopes
2002-10-05 by Sam A. McCandless
Is Hahnemuehle PhotoRag Duo, suitably cut down, a good, if expensive,
note-card stock for the MIS VM Sepia-Neutral ink set? I send too few
holiday cards for the expense to amount to much. And I need to learn
to print on PR anyway.
I thought I might use both the heavier, 308-gsm PR Duo for unfolded
cards (S-N image on one side and note on the other) and the lighter,
196-gsm PR Duo for folded cards with a S-N image on the front. Any
other printing I could do either with S-N or, on a second pass in
another 1160, with MediaStreet Enhanced Generations with the Gen4 K
replaced by the S-N K.
I assume the lighter Duo is heavy enough for folded cards? And that
it folds ok in one direction or the other; does anyone know which? Or
whether VM ink on the heavier Duo is scuff-resistant enough to be
used as a postcard rather than in an envelope?
Are envelopes available in a complementary color? I guess a match is
too much to hope for unless Hahnemuehle does them. I like Crane's
envelopes partly because I find their square-flap "Announcement Flap"
A2, A6, and A7 envelopes easier to print and write on. Either their
bright, Fluorescent White (what a name!) or their Pearl White would
probably be better with PhotoRag than Crane's warmer Natural White?
In addition to any advice about any of the above, I'd also be curious
to know what those of you who print your own B&W-image cards do with
other papers too.
Thanks.
Sam
