MIS-FS vs MIS-FSN
MIS-FS vs MIS-FSN
2002-09-30 by chatzebussi
Hello
can anyone direct me to a website with pictures showing the
tonal difference between MIS-FS prints (said to be slightly warm) and
MIS-FSN prints (said to be neutral). Thank you.
mathias muenger
P.S. any further experience-based comments on these two inks for the
EPSON 1160 with the built-in EPSON driver and EAM/EEM.
Re: MIS-FS vs MIS-FSN
2002-09-30 by Shilesh Jani
Mathias,
I don't know of any web-site showing the difference. I have used both
inks on a 1280 printer and EAM paper.  The difference is quite
striking. Side by side, the FS-N will look bluer than the FS.  But,
in reality it is very neutral.  The color of the paper is very
important to the look of these inks.  FS-N looks more blue with cool
papers such as EAM and Eclipse Satine Bright White. If you use a warm
paper (e.g., Hehnemuhle William Turner or Eclipse Satine Soft White),
FS-N inks don't look quite as blue. In my experience, these inks
don't work well with Somerset Velvet. Martin Wesley has done some
experiments with mixing the inks, and my recollection is that he
liked the 80%FS-N + 20%FS mix the best. But you may want to search
the archives to be sure.
Good luck.
Shilesh
--- In DigitalBlackandWhiteThePrint@y..., "chatzebussi"
<chatzebussi@y...> wrote:
> Hello
and
> mathias muenger
Re: [Digital BW] Re: MIS-FS vs MIS-FSN
2002-09-30 by Thom McGraw
I am not aware of side by side comparisons, but I will
give you my observations.
The FS prints looked way too greenish in tungsten
light.    However, they would warm up quite a bit if
left out in the open (sort of a yellowish brown).
Since I strongly dislike the appearance of green
prints and I am not overly fond of blue prints
(Straight FSN from what I have read) I decided to mix
FSN with FS (60 - 40).  Thank you Martin.
No more green prints in tungsten light.  As far as
warming with the new mixture, I don't know what will
happen since they have only been displayed for a few
weeks.
Paper and work flow:  EAM, German Etching, Photo Rag.
All used with Jeff Randall's ingenious curves.
Sommerset Velvet Enhanced doesn't print well with
these inks in my experience.
Thom
> showing the
> slightly warm)
> and
> > mathias muenger
> these two inks for
> the
> EAM/EEM.
2002-10-01 by Martin Wesley
Sent: Monday, September 30, 2002 4:48 PM
Subject: Re: [Digital BW] Re: MIS-FS vs MIS-FSN
Thom,
I had similar reaction to the FS and FSN. I am glad someone else is giving
blending a try. From the samples I did the warming of the FS seems to
dominate a bit so you may want to go a little colder out of the printer that
you would like.  You might try varying the ratio of the mix for the
different positions to let the hue change slightly with tone.
Martin Wesley
MIS FS-FSN blends
2002-10-01 by sceptre12345
Martin, Paul and others
I'm about to dispose of the original Piezo inks because of the
greenies associated with these inks (CIS - 2/3 full). The FS-N inkset
that I ordered should arrive this week.
But now I find out that the FS-N inkset may have a bluish cast while
the original FS inkset looks green under tungsten lighting. And now,
to compensate, some people are making the own blends from the two
inkset.
(Rant should go here)...lol
I've read message 19947 where Paul says that the FSN-K and the FS-K
are the same. In message 19691, Bob gives us a blending ratio of the
two inksets but Martin advises about being closer to the FS-N.
So, I'm ready to re-order some FS inks for blending, but I'm no
chemist and not much of an experimenter. So where should I be going:
80%-20% evenly across the two inkset ? I have an Epson 1160 with
Piezo V5.1.3e
TIA,
Andre
2002-10-01 by Thom McGraw
Thanks Martin,
I'll see how the warming goes with my current prints.
But it sounds from your experience I'll be mixing my
next batch at 75 - 25.
Thom
> of the FS seems to
> the mix for the
> with tone.
> Martin Wesley
