UV paper lignin test
2002-10-01 by Paul Roark
I have been told by an expert in paper longevity that lignin, perhaps the primary acid reserve in wood-pulp based paper, is photo sensitive, turning brown when exposed to UV light. While there are sophisticated tests for lignin (and one is going to be run on EAM), this expert suggested just exposing paper to UV or sunlight to see if it contains lignin. So, I decided to see what would happen to a variety of papers if I simply placed the papers with the paper backs almost touching a 15W UV fluorescent "black light." For the test, I selected papers from newspaper to the cotton papers. Because Eclipse is coated and optically brightened on both sides, I included one that I'd torn off the coating to be able to measure the cotton interior. The short summary of results is that the newsprint turned brownish in a day, whereas the other papers show almost no change after 100 hours. (The newspaper, by the way, tests out as neutral with the acid test pen, whereas the back of EAM tests as acidic. I have omitted the one day results for the "good" papers because there was no significant change.) The yellowing that I did observe in some of the "better" papers seems most likely to be optical brighteners in the paper base burning out and turning yellow, although I don't know why a premium paper manufacturer would put those brighteners in the paper base of a coated inkjet paper. (Xerox does put them into it's premium multipurpose paper, but that paper is not coated.) So, I don't think the yellowing of the allegedly premium papers means much. But, who knows? It appears that UV bleaches at least some paper slightly. As such, it might be that looking at the relative numbers is most telling -- that is, what happened to the yellow reading relative to the other readings. I assume that yellowing of the paper is not a good sign. Museo, the cotton paper with no brighteners, lost a unit of yellow, as did the interior of the Eclipse Satine cotton paper -- as also did EAM. These are the only papers to show this pattern. The detailed readings of the X-Rite are as follows (in order of C/M/Y/Visual density, and the decimal point is omitted): Control One day UV 105 hours of UV Newsprint 21/21/24/21 18/25/39/21 16/26/42/21 Xerox Premium Multipurpose paper 7/7/6/7 6/6/6/6 EAM 4/4/6/4 4/4/5/4 Eclipse 2/3/0/2 2/3/4/3 Eclipse inside 3/4/5/3 3/4/4/3 PhotoRag 3/4/3/4 3/4/4/3 LPM 4/4/2/4 3/4/5/4 Museo 2/3/4/3 2/3/3/2 Because there was so little change in this test, I went back and measured the backs of the EAM that has been subject to the longest fade test I've conducted -- 1200 hours of exposure to a fluorescent light. These are the results of that test: EAM control: 4/5/7/5; EAM back after 1200 hr: 4/5/7/4. My visual impression is that the 1200 hour test strip paper had yellowed just a hair. The longest non-EAM test I've done is with Hahnemuhle German Etching. That test went 500 hours. Here are the readings of the backs of the control and test strips for that paper: German Etching control: 3/3/4/3; 500 hour test: 3/4/5/3. Wilhelm allegedly rated EAM at only 30 years due to a poor paper aging test. I don't know what test he used, but what I see most using is a high temperature (90 C) test with humidity at 50 RH. The presence of water (humidity) is needed for acidity to have an effect. So, my rather crude test here for lignin is not necessarily contrary to what Wilhelm found. There clearly is some acid in the EAM paper backing. However, my test for lignin shows no evidence of significant amounts of it in EAM. Paul http://www.PaulRoark.com
