Jon Cone on New Blacks...
2002-10-03 by Thomas Fors
----- Original Message ----- From: "Jon Cone" <piezobw@...> To: <piezography3000@yahoogroups.com> Sent: Thursday, October 03, 2002 1:52 AM Subject: [piezoBW] New Piezography Products > Piezography News > > > At PhotoPlus Expo on October 31, we are releasing all 4 PiezoTone hue gray > sets and 2 new Piezography black ink positions. This will bring the total of > black inks to three. Additionally, ImagePrint by ColorByte Software will be > the first software product to support all of the Piezography inks. There is > support for the 1280/1290, 7000, 7500, 9000, 9500. Add'l printers are > planned. Cone Editions Press, Ltd will be providing the profile support, and > it will be a daunting task considering how many papers are now on the market > and how many inks we have (4 PiezoTone hues x 3 blacks = 12) > > The PiezoTone hue gray sets are Warm Neutral, Selenium Tone, Cool Neutral, > and Carbon Sepia. They comprise three gray dilutions available in 3 or 5 ink > sets. They are compatible with each other and with any of the 3 blacks. The > PiezoTone gray sets are made from 100% pigments without the use of dye or > metal complex. They are all carbon based with additional pigments added for > color. The Carbon Sepia is pure carbon without add'l pigments. If you liked > the warm faded look of the PiezographyBW inks (now Sundance Neutral Warm), > you will like this ink very much as it has the warmth but without the > density loss. Also the ink has been shaped to maintain the same directional > facets when dried down. There is nil metamerism and the ink can pick up > subtle hue differences depending upon paper. Very platinum like. Cool > Neutral is just off neutral to the cool side and does not have the blue look > of the other cool neutrals. > > The choice of blacks is going to expand to include inks which are suitable > for all types of quad printing. We did not design the original black for use > other than PiezographyBW software. That software uses a very small amount of > black in in proportion to the darkest gray (cyan position). The original > PIezoTone black has a very high Optical Density which was the highest > available at the time of its release. When printed with PiezographyBW > software it was not expected to produce any fade results which were > unacceptable. That is, they were expected to be similar to other inks on the > market. However, although we have not seen any printed samples of rapid > fading other than in pictures posted on the web, it is clear to us that it > is very unwise to experiment with workflows that the user is uncertain about > how it prints the individual ink components. > > Reports were made earlier in which it was noted that the black faded when > left on its own. We posted pictures which showed that the performance of the > inks were acceptable when used with Piezography. Paul Roark who has been > doing enormous amounts of testing and which we are very thankful for has > published data which shows that they are not acceptable when used on their > own. Using them with workflows is somewhere in between depending upon the > workflow apparently. Paul Roark found: > > PiezoTone Grays have a fading rate below 2% which is not discernable to the > human eye, and the similar ink positions of MIS-FS inks have a fade rate of > 18% and the MIS-FSN inks have a fade rate of 16.9% which are very > discernible. > > His tests show that using the PIezoTone black position only results in a 11% > fade rate and 5.8% and 3.5% respectively for the two MIS-Blacks. > > There wasn't any data published for the results of the black when used with > PiezographyBW other than comparative with MIS inks using photographs. The > PiezoTones do not change hue except in the black position which warm fades > while the similar ink FS completely fades warm. > > There are obviously different strengths when all the inks are compared, and > while none seem satisfactory on their own - combinations of products from > the two companies are winning favor. > > We introduced PiezoTone black because we were under the impression that the > majority of our users wanted a black which approached silver print and were > willing to have fade to an acceptable carbon base black - rather than a > black which did not fade at all but was less dark than current solutions. > > At the time it was not possible to produce from 100% pigment a black which > was dark enough. > > When we analyzed MIS-FSN by thin layer chromaticity testing it revealed 10% > AZO dyes and this would account for the 3.5 - 5.8% fades in Roark's tests. > > We gave our chemists the task of finding a way to make Carbon black denser > in Optical Desnity. We wanted a black at least as black as the MIS-FSN and > the old Piezo black - but we wanted it to have the performance of our > PiezoTone grays. That meant no dye no metal. They were able to produce a new > carbon black formula with this property by carefully shaping the carbon > particles. The result is a greater density and no need for dye or metal > complex to achieve a black similar to MIS. > > By the way the ingredient we used in the original PiezoTone black is a metal > complex not usually found in inks. Its property is extremely black mass > tone. > > Now that we have three blacks available I will detail their properties and > their attraction to users, or what is their strong points in difference to > each other which would make a user choose one over another. > > The original Black is for users who want a maximum black which nears Silver > Print OD. If used with PiezographyBW it will have fade characteristics which > are about congruent with our old black and other blacks on the market. It > will fade to its carbon content as the metal complex stuff that makes it so > black eventually fades. Its initial OD may make it appear to fade worse than > other blacks. But the ending points are very similar when used correctly. We > believe that this ink gives the greatest combined longevity and dMAX > currently available. But its selling point is that it is blacker than > anything else on the market and it has good fading characteristics. Some > users are experiencing problems with this ink of which the majority appear > to be from using it with RGB workflows which print great amounts of black in > conjunction with the yellow ink position. PiezographyBW software prints only > small amounts of black and not in conjunction to yellow, rather over the > dark position (cyan). Other users have commented to us in regards to > PiezographyBW software but it is not congruent with what we have > experienced. We do not think that this ink should be used with workflows > unless the workflow does not print large amounts of black ink. > > Experiment with this ink responsibly. We are not in a position to advise > which workflow is acceptable because we really do not support them. Before > PiezographyBW we partitioned the inks in about the same way using a CMYK > driver. Before that we created input/output tables for use with ConeTech > QuadBlack inks for IRIS. Our input/output tables were published for IRIS as > far back as 1994. We only know one way to print quad inks, a short black > over receding bell shaped curves in the cmy channels (if you can visualize > that you should be able to understand the output table). Now go make some > workflows which do it right.... > > > New carbon pigment made available to Piezography which is shaped differently > than previous carbon pigments will allow for greater density and hence > greater optical density. We should have this pigment exclusive for a year > (maybe a year and a half) and there is great optimism that we should be able > to further increase OD through continued shaping r&d. The two new black inks > based on this pigment follow: > > New Piezography MuseumBlack is pure carbon, no additional dyes or metal > complex. It is designed to stay at the same Optical Density (how dark it > is). In that regard it is like the PiezoTone Grays. The PiezoTone Grays fade > less than a couple %, which is not detectable to the human eye. So this > would be a rock hard combination. But it is not very black. It will start > out about as black for example as the MIS and Sundance Blacks. But the MIS > and Sundance blacks fade because of their dye content. MusuemBlack will not > fade to a discernible degree. So in the end MusuemBlack will appear to have > a much greater Optical Density than other black ink products. That will be > its selling point. We can do it without dye or metal complex now. Great > breakthrough. This ink is compatible therefore with any type of workflow and > should make a great black ink only black. > > New Piezography PortfolioBlack will end up at about the same OD as > MuseumBlack or just higher after its small amount of metal complex fades > out, but it will start off with a much blacker OD. It is in between > MuseumBlack needs and Original Black needs. It will perform better than the > original black but not be as black. Its final fade point is still being > tested and it may end up to be an exciting ink. Lets wait for the data and > compare then. > > If we extend this black even further with metal complex as we did with the > original black, we may see OD readings in the 2.1 and higher range. This may > open up a whole new can of whoopie. We are already testing formulas like > this with Xenon and in a few months may make some announcements which would > open up new opportunities in optical density but with fade. We are hoping > the fade like original black will be to levels congruent with the underlying > carbon. In the case of this ink, the underlying carbon can now be made > denser. So an improvement in the waiting. Maybe. We'll see whether extending > it is possible to make the OD worth the density loss. A version of this > black might make for a startling exhibition black where dramatic effect > unavailable in silver print is desired. The new carbon black is not as brown > as the blacks used in all the other inks on the market - so there may be > great hopes that this product can have an interesting future. We'll keep you > updated. > > > It will be interesting for us here to see how users react when presented > with three black choices that allow them to choose between aesthetics and > longevity. 72% of the users we polled answered they would rather have a > black that approached silver print and had fade characteristics to our older > dMax then a black which would not fade but was not very black. We had only > polled a small % of the user base and I think I will be surprised if the > Museum Black becomes the most popular. I think it will be a toss up between > the other 2. Perhaps we can keep a running poll going here in the next few > months as users try them all and decide... The running poll lets users go in > and change their mind as they begin to experiment. > > We will be supplying on or about PhotoPlus Expo complete Xenon data sets for > fading with all of our current and past ink products in comparison with > competitive products for analysis. > > There really is a lot going on and no one in Topsham has a minute to spare. > I am going to have to go back to my schedule. But I will read this list for > the remainder of the week. I will be traveling Thursday but should be able > to get on again in the evenings on Thur and Fri. So if there are questions I > will try and answer. I am sorry that neither myself or Bill has had time for > the lists. We are though answering e-mails sent to us directly. But this > should get out to many of our users. A mailing is planned with all the > printed ink samples and longevity testing data to our registered user base. > > > > Jon Cone > > > > To unsubscribe, send an email to: > piezography3000-unsubscribe@egroups.com > > InkjetMall.com now offers the lowest prices on the Internet on all popular papers for PiezographyBW!
> http://www.inkjetmall.com/store/products.html > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > > > >
