Hi Frank, i will try this I think. But I am not clear on one point.
The opacity changes, should they be applied to the background copy
layers or the curve layers? I can't see the benefity of applying it
to the curves (so I guess I've just answered my own question, duh).
Second point, is not using two copy background layers with two curves
layers and then applying blending and opacity changes not the same as
using only the background layer and applying the same transformations
to the two curve layers?
Hope that makes an ounce of sense....
Steve
--- In DigitalBlackandWhiteThePrint@y..., "frankg_photo" <frank@f...>
wrote:
> Here i am replying to my own post :-)
> After trying all day, I found tips posted by Bob ? to my first
pleas
> in August, which suddenly seemed decipherable and produced an
> immediate improvement.
> 1.make 2x duplcate layers of the background
> 2.place one of Paul's curves above the first duplicate & set the
Fill
> Opacity to around 70% & keep layer type Normal
> 3. on the 2nd duplicate layer, change the type to Overlay & the
> opacity to around 80%
> Dont ask me why or how - but this has made an immediate improvement
> to my prints.
> Can anyone delve deeper and/or finesse this procedure ?
> Frank
<frank@f...>
> wrote:
> > Even with using 16 bit scans and doing the major curve/level adj
> > before switching to 8 bit, I still have a problem with
> posterisation
> > in areas of my prints.
> > I have tried the same neg/scan on several paper samples I had
> (Royal
> > Renaissance (Photo Rag), Eclipse Satine Soft & the Bright, EAM) &
> > it's pretty much the same on all.
> > I am using MIS sepia>neutral inkset in an 1160 with Paul's curves.
> > In the past some have reported duplicating the background layer
> > and/or combining 2 curve adjustment layers and/or adjusing the
> > opacities - this is a muddle for me.
> > can anyone clarify this workflow or suggest another way I can try
> and
> > beat the posterization blues
> > thanks
> > Frankg
