F-16 failure -- new CFS
2002-10-03 by Glenn Thureson
I have the VM ink all set up and looking good.  However, when I turned on
printer (1280), the ink light was on.  So I went through all of the F-16
procedure (as far as I can tell), but to no avail.
I have gotten successfully through step 3c in the F-16 instructions.  Step
3d fails, 1280 ink light still on.  Then I went to Note 1 on page 5.  Still
no joy.  The ink light remains on.
And MIS is moving.
I would appreciate your help.
Glenn Thureson
Re: F-16 failure -- new CFS
2002-10-03 by Jeff Randall
Glenn:
Might be a problem with the F-16, the cart chips, or your printer.
If you have Epson carts that you haven't run dry, you might try re-
installing them to see if you can get a printer reset to eliminate
your printer as a source of the problem.  Remember to plug the outlet
holes of your CFS carts if you remove them even for just a little
while.  Make sure to turn the power off when removing and installing
the carts (some folks also unplug the power cable).
Jeff Randall
--- In DigitalBlackandWhiteThePrint@y..., "Glenn Thureson"
turned on
> the
F-16
instructions.  Step
5.  Still
> And MIS is moving.
> Glenn Thureson
