Blue eye calibrator.
2002-10-09 by aitor Peña Inclán
I have purchase a Lacie 22" monitor and thre is a especial offer for the
blue eye calibrator if I buy it with th monitor. I wonder if is a good
option to buy it. Or is better another solution, like the spider with
optical or others.
Best
Aitor
Re: [Digital BW] Blue eye calibrator.
2002-10-09 by Stephen Petegorsky
Altor - I have an older LaCie 22', and wish that I had bought the Blue Eye.
I've had the Colorvision Spyder, which works fine, but my assistant has the
Blue Eye, and it is a better system.  If you call or write them and ask them
to tell you the technical reasons why, I'm sure they will be glad to do so.
Stephen Petegorsky
petegorsky@...
www.spphoto.com
2002-10-09 by David Townend
There is one fact that may be a problem with the Blue Eye system that may be
worth mentioning... it will not work with any other manufacturers
monitors...
I have a LaCie and an Apple monitor, so I had to buy the ColourVision
Spyder...
Regards, David
You can view David's on-line folio at http://www.davidtownend.com/
and also the results of a recent job at http://www.globalrisks.royalsun.com
T - 00 44 (0)20 8374 6289
M - 00 44 (0)7770 622144
Thanks for the info,
I can buy the blue eye bundle with the monitor for 297 euros, or
a CRT only Spyder With Photocal for 179 euros. I doubt....
Aitor
> monitors...
> Spyder...
> Regards, David
Re: Blue eye calibrator.
2002-10-09 by thedigitaldog
--- In DigitalBlackandWhiteThePrint@y..., aitor Peña Inclán <aitorpinclan@t=
wrote:
> Hi,
> option to buy it.
If you can get a decent print, I'd for for the BlueEye as you'll be able to=
 use the
hardware/software as a "smart monitor' whereby calibration is done using th=
e
internal electronics in the display. Works pretty well. I think it's a good=
 system.
I think the price charged normally for the BlueEye is a bit high (nearly $6=
00). If
you can get a good deal, your LaCie 22" is made specifically to deal with t=
he
BlueEye so you don't need to mess with setting the guns. black/white
adjustments manually.
