Reflective Densitometer Method
2002-10-19 by Martin Wesley
I am fooling around with a used X-Rite 811 transmission/refection densitometry I picked up on eBay and I have a couple of questions for any experts on sensitometry lurking out there.
In reading reflective density of inkjet prints there is the issue that the paper is not completely opaque. You can see light though even the heaviest papers we are using. So when measuring image density the print being measured needs to be backed up with an opaque material. My question is should this be white, as in stacking up several pieces of paper under the print or should it be black? My inclination is to use black so that no light that passes through the paper gets bounced back, since this would logically seem to falsely increase the reflectance and lower the density reading. The calibration plaques are enameled metal so I assume the instrument expects to see a 100% opaque reflective target.
Dumb question: How do you convert RGB densities to CMY densities or do they simply equal their color opposites?
The 811 has two transmission modes, one for E-6 and one for C-41. Which would be the best for standard developed B&W film? Which mode would be best for yellow/green stained pyro developed B&W film?
Martin Wesley
http://www.borderless-photos.de/guests.html
RE: [Digital BW] Reflective Densitometer Method
2002-10-19 by Lloyd O'Daniel
Martin,
I've had a X-rite 810 for several years now. Your 811 is even a better
instrument. RGB does equal CMY. R= -C, G= -M, B= -Y. For B&W negs, the
811 should have a visual density (grey) mode. On the 810, this is
labeled T-VIS in the display.  You would use Status M color densities
for process control of C41 neg films, and Status A densities for E6. The
reflective mode should be Status A for reading prints. If your unit did
not come with a manual, you can buy one from X-rite. You also need
transmission and reflective calibration wedges from them as well.
Lloyd
Sent: Saturday, October 19, 2002 2:00 AM
Subject: [Digital BW] Reflective Densitometer Method
Martin Wesley
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=229441.2397090.3822005.2273195/D=egroupweb/S=1705
019182:HM/A=1189558/R=0/*http://www.bmgmusic.com/acq/ee/q6/enroll/mhn/9/
<http://us.adserver.yahoo.com/l?M=229441.2397090.3822005.2273195/D=egrou
pmail/S=:HM/A=1189558/rand=711387265>
unsubscribe, please edit your Membership preferences by visiting this
same page.
- As threads develop, trim off excess portions of earlier messages to
keep them short.
- As the topic of a thread changes remember to change the subject
header.
- Good manners are required at all time. No personal attacks or
&amp;amp;quot;flames.&amp;amp;quot;
resources on the homepage.
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
<http://docs.yahoo.com/info/terms/> .
Re: Reflective Densitometer Method
2002-10-19 by Jeff Randall
--- In DigitalBlackandWhiteThePrint@y..., "Martin Wesley"
<mwesley250@e...> wrote:
SNIP
SNIP
Martin:
Paul Roark and I discovered this discrepancy recently when reporting
on the offwhite EAM when I asked him exactly how he made his
measurements with his swatchbook because I was not getting the same
results.  I had discovered, as I played with my new
swatchbook, that backing color and opacity DOES make a difference.
As you have now discovered, the standard of practice is, and typical
instructions say to use an opaque black backing to absorb any back
reflected light.  However, the reasoning that I use to justify an
opaque white backing (like Paul) is that I frame my prints and use an
opaque white backing. So I want to measure what I will see.
Consistancy (using the same backing color and opacity) is also very
important.
Jeff Randall
2002-10-19 by Paul Roark
Martin,
I use a stack of white paper under the target just on the assumption that a
print will be mounted on an off-white mat board.  Consistency is probably
the most important thing.
___________________________
  Sent: Friday, October 18, 2002 11:00 PM
  Martin Wesley
              ADVERTISEMENT
page.
them short.
&amp;amp;amp;quot;flames.&amp;amp;amp;quot;
2002-10-19 by Antonis Ricos
Martin,
some "reflections" on your post:
With my 810 I find that on EAM I get the same readings whether I back it with
black or leave it alone. However, backing it with a second sheet raises the
paper white from 0.06 to 0.04. By the time you get to 15-20% of a grayscale
the difference is about 0.01 which is lost in the "noise" of the instrument. For
practical purposes, I always read EAM and Hahnemuhle without backing.
Consistency matters, but I can also see the argument that backing it with white
matches a matted print better. In any case, worth disclosing when we compare
notes on highlight densities.
Insterestingly, the DTP41 (XRite's strip reading spectrophotometer) has a
block under the sensor that can be moved to either white or black. The
instructions for PrintOpen, Heidelberg's profile-making software, asks that you
slide it over to expose the _white_  patch under the sensor.
Visual, marked as T VIS for transmissive ( R VIS for paper).
film?
Essentially none, but probably whichever gives you better separation of
values. These densitometers separate the spectrum into the 3 primaries
based on the peak frequency of the photographic color process dyes for
which their "status" is intended. Outside of that, their color readings are
meaningless as far as any standard reference goes and only useful as
"relative" values (perfectly functional for your purposes).
Antonis
2002-10-19 by sceptre12345
It seems the only difference between the two is X-rite 811 has status
A response for monitoring of E-6
Andre
--- In DigitalBlackandWhiteThePrint@y..., "Austin Franklin"
<darkroom@i...> wrote:
> Lloyd,
better
> > instrument.
> I'm curious what you think is better about the 811?
> Austin
The Status A transmission capability. I "rigged" my 810 to do that by
buying a status A sensor module, since one of my primary uses for the
810 was process monitoring of E6 for my Jobo ATL-2. The 811 would be
more accurate at high densities though, because the 810's internal
electronics are calibrated for status M.
Lloyd
Sent: Saturday, October 19, 2002 8:51 AM
Subject: RE: [Digital BW] Reflective Densitometer Method
Lloyd,
> instrument.
Austin
ADVERTISEMENT
<http://rd.yahoo.com/M=212804.2460941.3878106.2273195/D=egroupweb/S=1705
019182:HM/A=810373/R=0/*http://geocities.yahoo.com/ps/info?.refer=blrecs
019182:HM/A=810373/R=1/*http://geocities.yahoo.com/ps/info?.refer=blrecs
<http://us.adserver.yahoo.com/l?M=212804.2460941.3878106.2273195/D=egrou
pmail/S=:HM/A=810373/rand=634186675>
same page.
keep them short.
header.
Re: [Digital BW] Reflective Densitometer Method
2002-10-20 by Martin Wesley
Sent: Saturday, October 19, 2002 4:11 PM
Lloyd,
You may not be far off on the accuracy since the same calibration target and
values are use for both the Ta and Tm modes on the 811. Good bit of info on
converting the 810 though. I would think the E6 capability would be of more
use to photographers as I don't know anyone doing their own C-41 processing.
Martin Wesley
2002-10-20 by Lloyd O'Daniel
Martin,
That's what I was told by X-rite, although they were trying to sell an
expensive upgrade to an 811 at the time. ;-)
My unit originally came out of a C-41 minilab who traded up to a more
automated model.
Lloyd
Sent: Sunday, October 20, 2002 2:14 AM
Subject: Re: [Digital BW] Reflective Densitometer Method
Lloyd,
and
on
more
processing.
Martin Wesley
2002-10-23 by Bob Frost
Martin,
I seem to remember that Bruce Fraser and David Tobie both recommend stacking
multiple copies of the same paper under the target.
bob Frost.
