Re: [Digital BW] Arches Hot Press 140, K=2.40
2002-10-20 by Jerry Olson
Paul, are you saying Krylon Crystal clear spray on pigment inks on
Uncoated papers will enhance the d max?  Like Arches bright white? I
tried that spray with a few papers a long time ago, and didn't notice
any deeper blacks, but those were with somerset enhanced, Frankfurt, and
Royal Riviera.
What papers did you do this on?
Jerry
> The latest experiment in coating uncoated cotton paper:
> Krylon Crystal Clear to fix pigs.
> Two coats of out-of-the-can polyurethane.
RE: [Digital BW] Arches Hot Press 140, K=2.40
2002-10-20 by Paul Roark
Jerry,
No, I just use the Krylon to fix the pigs to the paper so they don't smear
when the water-based coating is applied with a rod.  On uncoated paper a
light Krylon spray is needed; it is not needed on coated inkjet paper.
Once the pigs are "fixed," then one coat gives about 2.3 and a second coat
is now over 2.5.
Like with wood, the first coat(s) "raise the grain" (or in this case
paper/cotton fibers).  Since we can't sand between coats, I found that the
dry mount press (with a release sheet) does the same thing.
The bottom line is that Arches HP gives a fantastic dMax and has a beautiful
finish.  The problem (though it less than with Stonehenge) is that the
prints have a graininess to them that is too much for my tastes.
So, unless there is an uncoated paper that prints smoother than Arches HP,
I'll probably stick with coated paper such as Eclipse or EAM.
Right now, my favorite paper for image quality, ease, and no post-processing
is EAM -- as usual.
If I want to coat a paper to get a high dMax I think Eclipse with a single
coat is my top contender.  The paper base stays nice and white, the dMax
hits 2.3, and the finish is a nice satin -- not too shiny.  Such a print in
a non-glazed frame could be very impressive.  (And I really don't like the
reflections of glass over the image, though it is the standard for display
B&W photos.)  The only disadvantage of the Eclipse with the 3000 is that it
is showing the pizza wheel tracks.  (I've never bothered to remove them.)
http://www.PaulRoark.com
Evening Paul,
I didn't much care for any of the varnished prints I've seen from the
group. Just don't like the look. Wonder if hot pressed arches smooth
papers would be as nice as the cold pressed? Maybe less grain.  I have
many sheets of Stonehenge and Arches left to experiment on. (22x30 inch
sheets).  Any ideas?
I'm still getting the best black and white prints using the 1160 printer
annd Generations 4 inks with enhanced black ink. Tobie made a profile
that is so accurate with color inks, that the black and white prints are
extremely neutral, with no color
crossovers.  For some reason, I get blacker blacks using color inks than
the VM inkset with enhanced blacks. I just may switch over to
Generations color inks in my 1280 and use that. They'll probably outlast me.
Jerry
