Help with Paper Feeding Problem Please
2002-11-29 by tech4x5
I am having a problem printing with my 1280 which just recently
started. I am using a PC with Windows 98 and Piezography v 6.0.2.
After I set up the dialog box, when I press OK to print, the paper
pulls all the way through the printer in one motion and stops in the
exit tray without printing.  Then the computer locks up with
hourglass and I need to reboot the computer and close and restart the
printer to try again.,  What is most frustrating is this is
intermittent, actually happening about 50% of the time in the last
couple of weeks.  I can't figure out a pattern.  It doesn't seem to
be related to paper type, thickness or size.  It doesn't matter what
setting I use in the Piezo dialog box, and in fact has even happened
when I try to print just with the Epson driver.  I have reinstalled
my Epson and Piezo software multiple times.  I can't figure out
whether this is a software issue, or whether there is a problem with
the paper feed in the printer.  I have the paper level set to + where
I have always had it set because I am using EAM and PhotoRag papers.
I am out of idea.  Thanks in advance for your help.
Matthew Kraus
