Piezo Dots...
2002-12-01 by markaronica
So here is the message that was censored from the Piezography Support Forum by tech support. I have to say that I find it very sad that they would try to control the flow of information regarding their products. The original problem was in regards to visible clumpy looking dots using the new PT-WN inks with PiezographyBW software (on EAM and other papers as well). There was an ongoing thread discussing this issue over on the Piezography forum. A number of us have also brought this to the attentions of Piezography Tech support to no avail. All that I've heard has been in the form of an Email message about two weeks ago saying that they were "looking into it." These dots are very visible in the gray transition below about 55%. Not only do prints with smooth dark gray transitions appear to band, but the dark gray areas of the print appear clumpy and lack a sense of continues tone prints. I thought that this might only be on Epson 1200 series printers, or only my printer, but a number of other forum participants confirmed this same problem in their prints as well. See the following for examples of the problem: http://www.aronica.com/patch/WedgeFull.jpg http://www.aronica.com/patch/WedgeCloseup.jpg http://www.aronica.com/patch/seaweed.jpg http://www.aronica.com/patch/seaweedcloseup.jpg My configuration is using Windows 2000 and pre-filled carts ordered directly from Inkjet Mall. Last week I switched to MIS FSN-E using a CIS and developed my own curves for EAM. I can now report that I am getting prints that are nearly as good tonality wise as the Piezo system. With the progress that I've made in the last few days, I'm convinced that with a little more playing around I'll have prints that at least equal the Piezo system in terms of producing the full tonal range. However, more importantly, making this switch has fixed the visible clumpy dots. I'm using the same printer and the exact same photoshop files with no changes. For example, the above image of the seaweed no long shows any of the dots visible in the above example. It is unfortunate that I was forced to leave the Piezography system as I really loved the lack of clogging and a number of other aspects of the system. However, the switch is like night and day. All the dot-ridden images produced under Piezography are now beautiful and dotless using the above MIS inks and the Epson driver. I hope this helps others to avoid making the costly mistake I made investing in the Piezo system. -Mark
