Re: [Digital BW] Re: Clogs from hell - maybe sometimes it's the ink? (cross posted)
2002-11-29 by Barry Kelsall
I used the
"10 cc Terumo Plastic Syringe"
fitted with the
"MIS Bottom Fill Adapter"
found at
http://www.inksupply.com/index.cfm?source=html/accessory.html
The adapter is inserted into the bottom exit port of the problem cart in the
CIS/CFS. There is a rubber seal in the cart which will help form a vaccuum
when pulling on the syringe plunger. If all is well ink flows freely into
the syringe through the CIS/CFS tubing & cart.
Good luck, Igor.
-BK
Sent: Friday, November 29, 2002 7:02 AM
Subject: [Digital BW] Re: Clogs from hell - maybe sometimes it's the ink?
(cross posted)
> Thanks for sharing your experience.
> About some details:
> Do you mean you just stuck the syringe into the CIS and sucked? Did
> it fit so precisely that you could get a vacuum?
> Or did you attached the syringe to the nipple inside the printhead?
> (I'm asking this because I might have a similar problem with my CIS
> and old Piezo ink).
> Thanks,
> Igor
> Amsterdam
2002-11-29 by Jerry Olson
I just put the syringe without needle on each chamber of the printhead
and squirted about 30 cc's ammonia water through. Be sure you have a
paper towel under the printhead, as a lot of it will be spilled, but
much will also get through. This, plus the cleaning of the bottom of the
printheads has always worked, unless your print head is dead.  Did you
get the email where I mentioned where you could still get the original
piezo inks if you want them?
Jerry
2002-11-30 by Barry Kelsall
The MIS black will dry out inside the tubing of a CFS until it forms a solid
plug. These systems can't sit unused for very long. I try to print at least
once a week.
-BK
Sent: Friday, November 29, 2002 10:59 PM
(cross posted)
> if you have a MIS type attachment on the syringe it will give you a
> vacuum.  I have had clogged black tubes in my MIS system.  Had to
> actually replace the tube to get back up and running, but then no
> problem... apparently it is only the black that clogs the tube.
> mark
> --- In DigitalBlackandWhiteThePrint@y..., "igorw2001" <iwesdorp@c...>
> > About some details:
> > and old Piezo ink).
> > Thanks,
> > Igor
> > Amsterdam
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and
page.
them short.
&amp;amp;quot;flames.&amp;amp;quot;
resources on the homepage.
2002-12-01 by Mark Hahn
I've had these clogs while using my printer nearly every day!
Bob at MIS said it only seemed to be more of a problem in Arizona and
New Mexico (I live in AZ).
mark
--- In DigitalBlackandWhiteThePrint@y..., "Barry Kelsall"
forms a solid
at least
> once a week.
> -BK
> From: "Mark Hahn" <markhahn2000@y...>
> To: <DigitalBlackandWhiteThePrint@y...>
the ink?
> (cross posted)
a
> > mark
<iwesdorp@c...>
> > > About some details:
Did
printhead?
CIS
> > > and old Piezo ink).
> > > Thanks,
> > > Igor
> > > Amsterdam
Polls and
wish to
this same
> page.
messages to keep
> them short.
header.
various
