Re: [Digital BW] VMS curves question and problem - Paul, others?
2002-12-02 by Julian Thomas
I've not used Pauls curves, but assuming that his curves are sound and this needs fine tuning - Build a modification grey curve whilst you are in greyscale. If you are using Paul's wedge, the numbers for each square are there, type the right numbers into the input/output box in curves. Then apply that curve, convert to rgb and try again. Julian ----- Original Message ----- From: "Murray Zaharia" <zaharia@...> To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Monday, December 02, 2002 9:10 PM Subject: [Digital BW] VMS curves question and problem - Paul, others? > > RE: [Digital BW] More on 'posterization again' > > This is going back to the above thread. > > I have printed out the 100 step greyscale wedge (Alex Pettit from > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/Image%2 > 0processing/ ) on my 1270 loaded with a new set of VMS inks in a CIS > onto Epson Archival matte paper. I had areas of my prints with no detail > that is clearly there on my file. It was in areas from approx 50 to 100 > in the info pallet. This is confirmed on my printout of the above > mentioned greyscale wedge. There is NO visual differentiation between > any individual squares between 54 and 99 (info pallet) on the greyscale > wedge that I printed out. I also scanned the greyscale wedge printout > and checked it out with the dropper (3x3 sample) in Photoshop as well > and it confirms the same. > > What is going on here? I can't see anyone being happy with this lack of > detail and the posterized look that results. Is there a possibility that > the curves are corrupted or something? Can the curves be adjusted to fix > this? I just cannot see that Paul would have been happy with these > results in the first place, therefore something must not be right. > > My settings in Photoshop 7: > > Working Space: Adobe RGB > Gray: Gray Gamma 2.2 > Print Space: Printer Color Management > > I am following to the letter Paul's instructions for his curves. > > I am using an Epson 1270 with the proper 1270 curve (vm70-NCA-w1) and > printing on Epson Archival Matte paper. > > Driver settings: > Matte Paper - Heavyweight > 1440 dpi > High Quality Halftoning > Microweave on > High Speed off > No Color Adjustment > > I have perfect nozzle checks as well. > > > > Please visit the Group Homepage to check the Files, Bookmarks, Polls and other resources as they are often being updated. The page is at: > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. > > Please follow these basic guidelines: > - Include your full name with your message. > - Include the address of your website, if you have one. > - As threads develop, trim off excess portions of earlier messages to keep them short. > - As the topic of a thread changes remember to change the subject header. > - Good manners are required at all time. No personal attacks or &amp;quot;flames.&amp;quot; > - Complete your Yahoo profile. > - Before posting a question, search the message archives and the various resources on the homepage.
> > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > > >
